Hi All,
I want to print packet fields in table format. I tried using display statement, but data was not aligned. Please let me know how to do this.
Rahul Kumar
Hi All,
Rahul Kumar
Are you using the UVM? There is a uvm_table_printer class to help with this. If not, you should be. :)
Thanks for reply. I am not using UVM, Is there any way to do this in simple systemverilog TB.
In reply to Rahul Kumar khokher:
Since you are not using a standard methodology, you will have do this manually by adding the appropriate spaces and using % width specifications in your $display statements.
Sometimes, if for nothing else, you can use the UVM reporting and printing methods alone without having to learn anything else.
how can i use $dislplay (or something else in OVM) to print a string with place holding
i know in c its like this:
printf(“%-6s”, string_s);
for example i have those vars:
string a = "kuku"
string b = "kukuku"
i want it to be displayed like this (6 characters) :
---------kuku ---------
---------kukuku---------
thanks!
In reply to gotlibhaim:
the page clean the spaces in the first print example
hope you’ll understand my question
Please use code tags to format your code in this forum. I have done that for you.
SystemVerilog has %6s that gives you minimum width right justified formatting. Some simulators have already implemented %-6s to get left justified. Neither format specifier truncates if the string is more than 6 characters.
