Passing value to macro
HI All,
I have defined a macro like below
`define form_name(arg) f_def_start_``arg
i wanted to pass value to the macro like below (defined inside a class)
string act_field_val;
for(int i=0; i<3; i++) begin
    act_field_val = `form_name(i);
however the result is “f_def_start_i” instead of “f_def_start_0, f_def_start_1, f_def_start_2”.
could anyone help.
In reply to Vdas:
https://verificationacademy.com/forums/systemverilog/2-variable-macro-definition-path-instance-inside-loop-not-working#reply-90856
