I have real variable as input to a module and in the instantiation of the module, I have the connected the real variable itself.
But still I don’t see the effect of it, when I try to display the same in module.
I know in verilog we can’t pass real type as ports ,but in system verilog we can pass.
I am not sure why this is not working.
In reply to yaswanth021:
It would really help if you put in some effort to show what you have tried, what results you are getting, versus what you expected to see. This tiny example works for me.
module myModule (input real p);
always @p $display($time,, p);
module test();
real r;
myModule m(r);
#1 r = 1.2;
#2 r = 3.4;
#3 r = 5.6;
and produces
# 1 1.2
# 3 3.4
# 6 5.6
module chk(input real val,input en)
real inv_val;
initial
wait(en)
$display("val is %t",val);
module abc()
real abc_val;
chk chk_inst(.val(abc_val),.en(en))
#20ns;
abc_val=130.0;
en=1;
I see the output of val is 0.000ns
OK, that is a little more effort. But you could have posted an example with no syntax errors. This code also worked for me.
module chk(input real val,input en);
//real inv_val; // you did not reference
initial
wait(en)
$display("val is %5.2f",val); // you used %t
module abc();
real abc_val;
bit en; // did not declare
chk chk_inst(.val(abc_val),.en(en));
#20ns;
abc_val=130.0;
en=1;
Because you used %t, your value gets scaled based on the current $timeformat specification and the default timescale your code was compiled with.
if want to drive testcases and want to keep the port signals , how we can do it?
Actually I wanted to connect DUT and test bench using schematic for that I need port signals of Testbench also
In reply to Kiran_amin:
I do not understand your question or how it relates to the thread here. You need to provide more details.
I have a ADC which takes analog input, to test this DUT I want to write testcase which provides real number inputs to the DUT.
I am connecting dut and TEST using schematic, so I have to keep the port level signals in my test also. So my input of adc becomes output port of my test.
Now how can I drive this real value to the DUT using test output port which shoulf be real data type?
module ADC(input vinp,…,vclk, output vout);
end module
//Here vinp is electrical
module test(output vinp,…,vclk,input vout);
output real vinp;
It looks like you’re trying to go between SystemVerilog and Verilog-A. You will need to contact your tool vendor for inter-language interoperability.
