module dut(input bit clk, input bit [7:0] addr, input bit [31:0] data);
always @(posedge clk)
$display("%0d, %0d",addr,data);
//module dut_wrapper(interface i);
module dut_wrapper(ex_if i);
dut my_dut(
.clk(i.clk),
.addr(i.a),
.data(i.d)
interface ex_if#(W1,W2)(input bit clk);
bit [W1-1:0] a=3;
bit [W2-1:0] d=5;
endinterface
interface bad_if(input bit clk);
bit [7:0] a=4;
bit [31:0] d=6;
endinterface
module Top;
bit clk;
clk = 0;
#(2us);
forever begin
clk = ~clk;
#(1us);
ex_if#(8,32) my_if(clk);
dut_wrapper DUT(.*,.i(my_if));
I have 2 questions:
As this example works, it seems I can define the dut_wrapper module with an ex_if type port, without prior declaring ex_if? Similar to just using a generic interface reference (line commented out)? I find it a bit weird as the compiler doesn’t even know that ex_if is an interface at the moment it compiles dut_wrapper.
The LRM shows parameterized interfaces passed to modules, but only using the generic interface. My code above tries to be more strict and limits it to ex_if interfaces. However it seems I am not allowed to put the parameters in there? I.e.
module dut_wrapper(ex_if#(8,32) i);
does not compile. So there is no way I can restrict it to a particular parameter specialization? Not a big deal, I was just expecting that it would have been required to put the parameters, not that it is not allowed to put them.
You are correct, there is no way to restrict interface ports to particular parameter specializations, but you can put elaboration-time checks inside the module that it connects to the interface.
bit [W1-1:0] a=3;
bit [W2-1:0] d=5;
endinterface
if (i.W1!=8) $error("W1 not 8"); // this is a generate block
ex_if #(7,8) i1();
dut_wrapper DUT(i1);
Say I use this module as interface_wrapper which binds at the TB Top. And this module contains the code to set the static interface to the testbench using config_db. Example code as shown below.
uvm_config_db#(virtual ex_if)::set(null, "*", "ex_if_vif", i);
But I face the compatibility issue with respect to the uvm_config_db, because the default element in the uvm_config_db expects a default parameters for the interface, but while we pass the interface to the module we set different parameters to the interface.
So how can we pass the parameters that you use to for the interface and pass the same to the uvm_config_db #(virtual ex_if #(? ?)).
Do I need to pass that as parameter inputs to the interface wrapper module and then set in the config_db as show below ? so that the data types matches ? [Because this way was able to configure the right parameters to the interface and as well to the virtual interface defined in uvm_config_db]
Yes, parametrization is part of the type of a virtual interface, so you need to make sure the parameterizations match.
There are many strategies for dealing with parameter matching problem, the simplest being to avoid using parameters unless absolutely necessary. There are many papers presented at the various DVCon conferences, one such is here.
