I have a couple of questions about passing array by reference to a task
1 - i have a task with the following prototype
task my_task (ref [31:0] array);
in my testcase, i have the following variable static logic [31:0] testcase_array[5];
and i call the task : my_task(testcase_array);
i have the following error : ref formal and actual do not have equivalent data types (expecting datatype compatible with ‘dynamic array of packed array [31:0] of logic’ but found ‘unpacked array of packed array [31:0] of logic’ instead).
Is not it valid to pass fixed size array to dynamic array argument ?
2 - The second question : When passing array with reference, each element is considered to be passed by reference ?
The type compatibility rules for an argument passed by reference is very strict. This is because any operation performed on the argument inside the routine is effectively being operated on the argument passed to the routine. You rarely need to pass an argument by reference unless you are calling a time-consuming task and need to have the argument updated while the task is blocked.
For your second question, arrays are aggregate data types and treated like a single object. So the entire array is passed as a single reference.
You can’t pass a wire by reference, only variables.
A better solution is to use the bind construct to bind a module with a port connected to the wire. That module can have a task inside it that directly references the port.
