I am trying to get some values to struct based on a packed array. It seems rsp.addr when it gets value from packed array p_data[1][11:4] which i expect it to be 'hbc. It seems 2/3 simulators give the correct results. any problem with the below code?
module tb;
typedef struct packed {
logic bs; //31
logic [2:0] ecc;// 28
logic [7:0] addr; //20-27
logic [15:0] data;// 4-19
logic [3:0] par; // 0-3
} req_s;
req_s req,rsp;
bit[1:0][17:0] p_data;
req = 32'habcdefab;
p_data[0] = 18'h1efab;
p_data[1] = 18'h1abcd; // 01_1010_1011_1100_1101
$displayh("struct=%p",req);
{>>{rsp.addr}} = p_data[1][11:4];
$display("rsp = %p",rsp);
// 01_1000_1000
