NULL FOREIGN FUNCTION POINTER ENCOUNTERED
I am using dpi to invoke c function in my systemVerilog environment.
For the following code
import “DPI-C” encoder=function void encoder(byte input_buf[3000],byte parity[500]);
encoder(input_buf, parity); //calling the function
If the File in which function encoder(…,…) is present is a cfile(.c) then simulation works well.
But if that file is c++file(.cpp) then it gives a fatal error saying null foreign function pointer encountered while calling encoder.
function is defined as…
void encoder( unsigned char *input_buf , unsigned char *parity)
Can anyone help me with this
In reply to ganesh shetti:
note: include "“svdpi.h” is included
DPI functionality expects that the compiled C functions support ‘C’ linkage. Since C++ uses function overloading, it will ‘mangle’ the function names, making them incompatible with standard C linking.
You need to preface your function declaration with ‘extern “C”’ to tell the C++ compiler/linker to not mangle the function name.
Most modern SystemVerilog simulators will generate the appropriate C/C++ header file for your DPI functions. Please refer to your user manual and use this feature if available instead of trying to write your own header file.
extern C using in c function. because I am facing issue in c language only . this is my c function :
 static void str2bytes(const char* hex, uint8_t* bytes)
and in sv :
import "DPI-C" function void str2bytes(input string hex, output byte bytes[]);
this is my import function still i get a error
