I want to constraint variable a such that it has one bit set high (one hot ) and it should be negative number meaning -1, -2 … -1024 with min and max set as -1 and -1024
shortint a;
constraint c1 {
a inside [[-1: -1024]} -> $countones(a) ==1;
Above code is incorrect i feel
In reply to tejasakulu:
Not only is your code incorrect but your constraints cannot be satisfied. There is only one negative shortint number with only one bit set—16’sh8000, or -32767.
Can you please tell me what is wrong in here if i have to generate negative numbers with just one bit set
Can you give us an example of a negative number you would like to see generated with only one bit set? I can only think of one: -32767.
Maybe you mean a negative number with the sign bit set and one other bit set. That would be 2 bits set. Neither -1 nor -1024 meet those constraints.
Or maybe you mean a negative number whose absolute value has only one bit set. Then both -1 and -1024 meet those constraints.
A negative number with the sign bit set and one other bit set. That would be 2 bits set.
Yes you are correct example of negative number FFF0 is -16
Then that would simply be $countones(a) == 2, not equal ==1.
rand shortint a;
constraint c1 {
a inside {[-1024:-1]} && $countones(a) ==2;
-16 has 12 bits set.
Above constraint has error of conflicting constraints
Oh, you can’t use a shortint and restrict the range.
class A;
rand bit signed [10:0] a;
constraint c1 {
a inside {[-1024:-1]} && $countones(a) == 2;
A h=new;
initial repeat (10) begin
assert(h.randomize());
$display("%h %d",h.a,h.a,);
