Need clear understand of handle
We create handle and objects for a class.What are the major differences between handle and object.When we need to create handle.
See a screenshot from our regular VSV training (http://www.cvcblr.com/trng_profiles/CVC_LG_VSV_profile.pdf) that covers this topic.
HTH
Ajeetha, CVC
In reply to Ajeetha Kumari CVC:
I like to think of three distinct concepts: class variables, handles and objects.
A class object is an instance of a class definition that you create when you call its constructor function - new(). In SystemVerilog, all class objects are created dynamically; on or after time 0. The LRM does not specify how or when an object can be destroyed - only when it cannot be destroyed.
A class variable is variable whose value represents a reference to a class object. Like any other variable, the lifetime of a class variable depends on how and where it is defined (static, automatic, or dynamic).
The value that represents a reference to class object is called a handle. You can never see or represent the literal value of a handle (except for the special handle: null). You must use the class variable in an expression to reference members or methods in the class object using the class handle stored in the variable.
Iam pretty confused with your explaination.Actually class variables means either Objects/handles which will be created in below fashion.
Class_name clss_variable;//class variable nothing but object/handle.
I just need when we use handle and when we use object,What is the difference between both of them.
Regards
Bharath
In reply to Lucky:
Bharath
If you run this complete example
class class_name
  int i;
class_name class_variable;;
initial $display("Hello World");
you will have created a static variable class_name but no class object. So no handle exists to class_name. Now a call to the constructor.
        class_variable = new();
        class_variable.i = 1;
        $display(class_variable.i);
new() is a function that returns a handle to an object of class_name.class_variable.i means use the handle stored in class_variable to reference an object, and select variable i of that object. In C/C++, this would look like the pointer reference class_name->i; In SystemVerilog, you never use the object directly, you always reference is using a handle stored in a class variable.
Thanks,Your explanation is pretty clear.
Regards
Bharath
What happens when I pass the object handle as an input argument to a function ?
Is it a pass-by-value or pass-by-reference ?
If the function changes the value of a variable inside the object, will it affect the original object’s handle ?
In reply to Mustafa Kamal:
https://verificationacademy.com/forums/systemverilog/can-task-arguments-which-are-class-variables-object-handle-be-always-treated-pass-ref-type-argument#reply-75354
