I have developed my testbench and I can run it and everything works fine but for Only first sequence. After That the test runs infinitely can’t execute the other sequences.
I think It’s stuck in wait statement in monitor. But I don’t know why the driver does not start the second sequence. What could be causing that it stops after the second sequence ?
UVM Log:
UVM_INFO ../agent_hl/monitor_hl.sv(30) @ 365: uvm_test_top.env_h.agnt_hl.mn_hl [uvm_test_top.env_h.agnt_hl.mn_hl] Here Again
UVM_INFO ../seq_iteml.sv(56) @ 365: reporter@@item [item.do_compare()] Cast succeded.
UVM_INFO ../scoreboard.sv(32) @ 365: uvm_test_top.env_h.scb [uvm_test_top.env_h.scb] Transaction Passed
Monitor run phase Code:
forever begin
item = seq_iteml::type_id::create("item");
`uvm_info(get_full_name(),"Here Again", UVM_HIGH)
//`uvm_info(get_full_name(),"Here Again", UVM_HIGH)
//`uvm_info(get_full_name(),$sformatf("\ndata ready = 0x%h \n", vif.o_TX_Ready), UVM_HIGH)
@(posedge vif.i_Clk or negedge vif.i_Clk);
wait(vif.i_TX_DV == 1)
item.data_in = vif.i_TX_Byte;
wait(vif.o_RX_DV == 1);
item.data_out = vif.o_RX_Byte;
`uvm_info(get_full_name(),item.convert2string(), UVM_HIGH)
mhl_analysis_port.write(item);
Driver run phase Code:
reset_vals();
forever begin
seq_item_port.get_next_item(item);
forever begin
@(posedge vif.i_Clk);
if(vif.o_TX_Ready) begin
`uvm_info(get_full_name(),$sformatf("\ndata_in = 0x%h \n", item.data_in), UVM_HIGH)
vif.i_TX_DV <= 1;
vif.i_TX_Byte <= item.data_in;
break;
//drive();
seq_item_port.item_done(item);
vif.i_TX_DV <= 0;
