When we have multiple reset to be taken care for RAL, how do we do it for the following situation:
Lets say register A which has 5 register fields A.A1, A.A2, A.A3, A.A4, A.A5.
We have 2 resets rst1 and rst2.
A.A1 and A.A2 are reset by rst1.
A.A3, A.A4 and A.A5 are reset by rst2.
I’m not sure if this is a practical scenario. How do you handle the reset of single register fields in the DUT? I believe this is impossible.
But the RAL provides 2 different reset options. The intention is to oerform the reset from 2 different sources (HARD, SOFT).
Let’s assume we have a register block called reg_block and it contains 2 registers A and B.
Register A has fields A1, A2, A3, A4, and A5.
Register B has fields B1 and B2.
A.A1 and A.A2 are reset by rst1 as well register B.
Typically you reset your register model either in a reset phase of a test, where you start your reset sequence or it might be you have a running process for detecting reset and then you reset your register model.
If the whole register block and its registers have the same reset signal, that’s clear once the reset signal has been detected we just call reg_block.reset(), and that call by default calls reset() of each register and each register field.
In your case, we need to single out register A and its fields as it’s a special case.
So for example assuming we have 2 running processes for detecting rst1 and rst2, it would look like the following.
class test extends uvm_test;
// .. constructor
// .. build_phase
virtual task main_phase(uvm_phase phase)
phase.raise_objection(this);
detect_rst1();
detect_rst2();
join
phase.drop_objection(this);
virtual task detect_rst1();
uvm_reg regs[$];
uvm_reg_field fields[$];
uvm_status_e status;
wait(rst1);
reg_block.get_registers(regs);
foreach (regs[i]) begin
if (regs[i].get_name() == "A") begin
regs[i].get_fields(fields);
foreach(fields[i]) begin
if(fields[i].get_name() inside {"A1", "A2"}) fields[i].reset();
end else begin
regs[i].reset();
virtual task detect_rst2();
uvm_reg regs[$];
uvm_reg register[$];
wait(rst2);
register = regs.find with(item.get_full_name() == "A");
register[0].get_fields(fields);
if(fields[i].get_name() inside {"A3", "A4", "A5"}) fields[i].reset();
Note: this code is just a pseudocode to explain the idea and is based on my understanding of the problem. If you want an exact code, you could share your testbench environment setup.
