In the design with single clock domain, all the sequential logic is sensitive to one event @(posedge clk).
In a testbench for that design, we can have multiple clocking blocks defined associated with that DUT clock.
Say,
clocking cb0 @(posedge clk);
clocking cb1 @(posedge clk);
If there is some code in a process:
begin: process_x @cb0; @cb1;
Is it possible that simulator triggers cb0 event first, then immediately resume the process_x which would suspend on cb1. Then simulator triggers cb1 at the same clock edge, making the whole process cost only one simulation cycle.
Upon processing its specified clocking event, a clocking block shall update its sampled values before triggering the event associated with the clocking block name. This event shall be triggered in the Observed region.
Seems this is small but important difference between @cb and its associated @(posedge clk).
when simulator sees posedge clk event in the active region, it schedule trigger of clocking block events into the observed event queue. And when simulator executes events from the observed event queue, it copy the events into the active region and execute them from there.
while (any region in [Active … Post-Observed] is nonempty) {
execute_region (Active);
R = first nonempty region in [Active … Post-Observed];
if (R is nonempty)
move events in R to the Active region;
I have a fundamental question about this reference algorithm.
Is event from the active region executed in place in the active event region OR the events get copied out of the active region to a temporary buffer essentially making the active region empty before the event execution? Because event triggering might resume more suspended processes which would be put into active region. I wonder evaluation(execution) of these processes are in the next round of active region scheduling or right in the same round of event triggering.
Hi Dave, since posedge clk is clocking event for both cb0 and cb1, triggering cb0 and cb1 in observed region as ONE update event or separately? The LRM doesn’t define this at all.
If cb0 and cb1 are triggered from separate event from Observed region, then according to the reference simulation algorithm,
execute_region {
while (region is nonempty) {
E = any event from region;
remove E from the region;
if (E is an update event) {
update the modified object;
schedule evaluation event for any process sensitive to the object;
} else { /* E is an evaluation event */
evaluate the process associated with the event and possibly
schedule further events for execution;
The following steps are possible:
0. move all events from observed region to active region
cb0 update event is removed from active region and executed. The cb0 gets triggered; evaluation event for process_x execution is scheduled into active region
process_x move forward and wait for @cb1. process_x get suspended
cb1 update event is removed from active region and executed. The cb1 gets triggered; evaluation event for process_x execution is scheduled into active region
process_x move forward and finish.
This way the whole process_x only consumes one cycle.
