I export a dynamic task to C++ test bench, but the task looks skip forever loop.
How can I resolve it?
export "DPI-C" task freq;
task automatic freq(); // global task
bit a = xDUV.aa;
bit b = xDUV.bb;
$display($time,">>> a= %b, b=%b", a, b); // display OK
forever begin: checking
$display("forever start"); // No displaying
@(negedge b)
$display($time,"b enabled");
@(posedge a);
@(posedge a)
if(!b)
$display($time,"ERROR");
disable checking;
join_none
The variables ‘a’ and ‘b’ are assigned values when the task is called. These values will never change, hence it appears that your forever loop never executes.
the frever loop never executes if assigned value would not be chaged. But even though I think the first $diaplay(“forever start”) should be worked.
I re-tested your comment as below, but the first display works well in usual verilog task call, not by DPI-C.
//export "DPI-C" task freq;
//Call in verilog module
bit a = 1;
bit b = 1;
$display("forever start"); // diaplay OK
@(negedge b)
@(posedge a);
@(posedge a)
if(!b)
disable checking;
join_none
