Hi All,
Can anyone suggest the best way to capture interleaved data in uvm monitor?
Scenario:
2 bit signal (channel): having channel numbers 0,1,1,2,0,0,0,0,2,2,1,1,2,1,1,0,2,1,0,1
1 bit signal (start) : assert high for 20 clock cycle and then assert low.
8 bit signal (data) : random data on every clock cycle.
Need monitor to capture this interleaved data.
Thanks.
In reply to KMarshall:
Not really clear what the monitor needs to write out as a transaction. Perhaps you can give some example scenarios
Scenario:
- Every clock (channel number) is changing (0/1/2).
- Corresponding to each channel, data is there.
- The moment 1-Bit signal (start) assert,
data corresponding to each channel should start getting filled in an (analysis port) and should stop on de-assertion of (start) signal.
Please let me know, if still information needed. Else let me know the option to update waveform picture.
What data structure/transaction do you want the monitor to send out it’s analysis port and when should it do that? It would help to show that in terms of a class definition.
bit [31:0] channel_data [channel_number][$];
Data will be pushed to each queue depending on channel number, from assertion of “START” signal, till de-assertion.
Is it the right approach?
