I created APB monitor class in system verilog testbench.But it is not working properly.plz give me idea.
task monitor_read(); //read monitor task for read operation
@(mon_if.mon_cb);
wait(mon_if.mon_cb.wr_rd==0);
wait(mon_if.mon_cb.sel==1);
wait(mon_if.mon_cb.enable==0);
repeat(1)@(mon_if.mon_cb.enable==1);
data2rm.wr_rd = mon_if.mon_cb.wr_rd;
data2rm.sel = mon_if.mon_cb.sel;
data2rm.enable = mon_if.mon_cb.enable;
data2rm.addr = mon_if.mon_cb.addr;
data2rm.data_out = mon_if.mon_cb.data_out;
endtask: monitor_read
virtual task start_read();
forever
$display("%0t=========start of monitor method================",$time);
monitor_read();
new_data= new data2rm;
mon2rm.put(new_data); //put transaction in to monitor to ref. model mailbox
mon2sb.put(new_data); //put transaction in to monitor to scoreboard mailbox
$display("%0t============end of monitor method===============",$time);
join_none
endtask:start_read
In reply to p_patel:
It would really help if you used code tags and explained what you expected your code to do versus what you observed it doing. It would save a lot of time for the people trying to help you.
A couple of quick observations about your code:
You have
repeat(1) which doesn’t do anything. Why did you put it there?
A lot of people get into trouble mixing clocking events with other event controls. I suggest that once you have a process with
@(cb), use that as your only event control. So you may want to re-write your code as
@(mon_if.mon_cb iff
(mon_if.mon_cb.wr_rd==0 &&
mon_if.mon_cb.sel==1 &&
mon_if.mon_cb.enable==0) );
@(mon_if.mon_cb iff mon_if.mon_cb.enable==1);
My driver class for APB read operation is following:
virtual task start_read(); //read task for read operation
$display(“%0t================start of read method===================”,$time);
gen2drv.get(data2put);
@(drv_if.drv_cb); //whenever clocking event happen
drv_if.drv_cb.addr<=data2put.addr; //passing pin level information to inteface
drv_if.drv_cb.wr_rd<=data2put.wr_rd;
drv_if.drv_cb.sel<=data2put.sel;
drv_if.drv_cb.enable<=data2put.enable;
repeat(1) @(drv_if.drv_cb); //after 1 cycle delay assign enable signal to interface according to protocol
drv_if.drv_cb.enable <=1'b1;
repeat(1) @(drv_if.drv_cb); //after 1 cycle delay make enable signal low-according to protocol
drv_if.drv_cb.enable<=1'b0;
drv_if.drv_cb.sel<=1'b0;
drv2gen.put(data2put);
$display("%0t wr_rd in driver for read=%0d",$time,data2put.wr_rd);
$display("%0t addr in driver for read=%0d",$time,data2put.addr);
$display("%0t sel in driver for read=%0d",$time,data2put.sel);
$display("%0t enable in driver for read=%0d",$time,data2put.enable);
$display("%0t===================end of read method====================",$time);
endtask:start_read
But whatever you gave code following is not working for APB monitor:
@(mon_if.mon_cb iff
Can anyone guide me for the above issue?
