Hi,
I know for calling any module/interface through function-for loop needs constant value. Other wise it will generate cross module error.
Example code:
module LANE();
function reset_lane(int a);
$display("LANE[%0d] is Reset",a);
endfunction : reset_lane
endmodule : LANE
module top();
LANE ln[0:15]();
main main_i();
endmodule : top
program main();
function start();
for(int i=0; i<16; i++) begin
$root.top.ln[i].reset_lane(i);
endfunction : start
endprogram : main
Now I need to target reset_lane method for each module using for loop in program-function not in program-initial.
How can I play with this scenario?
Regards
In reply to electron:
Hello,
I believe here reset_lane function in Modeule LANE is to reset perticular Lane!
If you want controlabilty from testcase, You can use abstract class method to do so. Where you dosnt have to use $root and wont be any issue to use reset_lane method to call in any Program-function.
Please refer Section 8.21 from SV LRM.
Regards,
Vinay Jain
In reply to Vinay Jain:
Hi Vinay,
That was just an example to define my scenario. I need to call any of the module method here reset_lane through function-loop from program block.
I don’t get this, Could you please elaborate?
I now use interface classes instead of an abstract/virtual classes when the abstract class only contains pure virtual methods. The benefit of using an interface class is that you can implement multiple interface classes in a single class while also extending from another class.
package my_api;
interface class lane_api;
pure virtual function void reset_lane(int a);
endpackage
module LANE();
// implementation of lane_api
class lane_api_imp implements my_api::lane_api;
LANE.reset_lane(a);
endclass : lane_api_imp
function lane_api_imp create;
create = new();
endmodule : LANE
module top();
LANE ln[0:15]();
main main_i();
endmodule : top
module main();
import my_api::lane_api;
lane_api lane_h[16];
function automatic bit init_lane(int n, lane_api h);
lane_h[n] = h;
for(genvar i=0;i<16;i++) begin
// I used a static variable initialization instead of
// an initial block to avoid race conditions with the initial
// block below
bit a = init_lane(i,$root.top.ln[i].create());
function start();
lane_h[i].reset_lane(i);
endfunction : start
initial
start;
endmodule : main
