Mirroring signals in classes
Sorry for posting something which is related (a bit) with specific simulator but hopefully this could be of some interest. BTW, I am moving to Questa from IUS, just FYI
I am encapsulating into a class a fifo verifcation unit for a mixed VHDL (DUT RTL) and SV (tes bench evironment.
This is why I need forcing and mirroring (unfortunately cannot ‘bind’ since the VHDL RTL uses unconstrained array defined, and looks like SV cannot handle this)
I actually got rid of ‘forcing’, having issues with mirroring. Below is an over simplified code for sake of simplicity.
Some initial comments:
the task set() forks fine, i.e. i can see the effect of forcing value into the signal eep into dut
the contructor get the dut path form the caller
SIMFORCE and SIM_MIRROR re macros hiding the simulation dependent suff underneat (e.g. $nc_mirror or $init_spy … please ignore this)
class cl_fifo_bfm;
  typedef struct packed {
     bit                overflow;          //: std_bit;
  } status_t;
     bit                irq_req_en;         //: std_bit;
     bit                half_mode;          //: std_bit;
  } control_t;
  // private variables
  local rand control_t _control;
  local status_t       _status;
  local string         _dutInst = "";
  // apply control register to the DUT
  task set;
    `SIM_FORCE(
       $sformatf("%s.mif_fifo_control.irq_req_en", this._dutInst),  // dst
       "",                                                 // place holder???
       $sformatf("2#%b", this._control.irq_req_en) // src
    `SIM_FORCE(
       $sformatf("%s.mif_fifo_control.half_mode", this._dutInst),  // dst
       $sformatf("2#%b", this._control.half_mode) // src
  endtask: set
  // no half mode
  constraint c0 {
       this._control.half_mode         >= 1;
  task mirror();
    logic _overflow;
     `SIM_MIRROR(
      $sformatf("%m/_overflow"),                    // dest
      $sformatf("%s/fifo_status.overflow", this._dutInst)  // src
//    assign #10ps this._status.overflow = _overflow;
  endtask:mirror
  function new(string inst);
    this._dutInst = inst;  // instance of the fifo mif_fifo_control
    `SIM_MIRROR(
      $sformatf("%m/this._status.overflow"),                    // dest
  endfunction: new
endclass: cl_fifo_bfm
here is how I create two istances of the class (one FIFO for inphase and one for quadrature)
           static cl_fifo_bfm fifo_bfm [2];
              fifo_bfm[0] = new( $sformatf("%s/i_hm_core/i_fifo_monitor/i_fifo1_i", dut_path) );
              fifo_bfm[1] = new( $sformatf("%s/i_hm_core/i_fifo_monitor/i_fifo1_q", dut_path) );
	      fifo_bfm[0].mirror();
	      fifo_bfm[1].mirror();
The task mirror() compiles and executes but I cannot see the signal correctly mirrorer: the toggle in the DUT but not in the _status members.
Mirroring fron the constructor does not work either.
Can you see any problem in this approach? e.g. task calling in an initial block? anything else?
As I said, foring works like a charm
		  foreach(fifo_bfm[j])
		    begin: p_iq
                      fifo_bfm[j].randomize();
		      fifo_bfm[j].set();
                    end: p_iq
thanks for the help
In reply to stanzani:
I think you will need to contact your vendor directly for support. This mirroring functionality is specific to the tool, and there may be limitations on system function’s use.
Thanks Dave
I see there is a simulator-independent way for doing this using force / release SystemVerilog keyword. I cannot find an SystemVerilog keyword for mirroring, though
The need for signal mirroring was predicated by the fact that VHDL had no hierarchical references. If you need to know the value of a signal deep inside your DUT without passing it up through ports, vendors added this capability with simulation specific applications. This was also the way to grab the values of signals between languages.
Now that VHDL has hierarchical references, there is no need for this mirroring capability. You use the referenced signal name directly instead of having to create a local variable that gets automagically updated.
However, whenever crossing standard language boundaries, you need to consult your tool vendor’s manuals to see what it can support as there is no standard for interoperability between two different standards at the same time.
