Mirrored value in frontdoor and backdoor
Hello Guys ,
When I call the Write method using BACKDOOR access, the desired value and the mirrored value are the same.
However, with FRONTDOOR access, when I call Write, the desired value differs from the mirrored value.
even after calling ‘Read’ , the mirrored value is differs from the desired value
Could you please explain why this happens? Should I add a predictor to resolve this issue?
Thanks!
You need an explicit predictor(recommended) or implicit prediction.
