Reg Model Mirrored value doesn't change
Thank you for your response.
Looks like I have figured out the problem.
I haven’t implemented the explicit predictor, therefore I need to manually do reg_model.default_map.set_auto_predict(1) in order to do the automatic predict, which is OFF by default in UVM1.2.
With this change I can see the mirror value starts to change.
