class stimulus;
logic [2:0]opcode;
logic [7:0] op1,op2;
task gen;
op1 = $random;
op2 = 'd8;
opcode = $random;
#1 stimulus_vectors();
op1 = 0;
op2 = $random;
opcode = opcode + 1'b1;
op1 = $random;
op2 = ~op1;
opcode = 3;
op1 = $random;
op2 = $random;
opcode = $random;
task stimulus_vectors();
$display("stimulus vector is : at %g",$time);
$display("[Stimulus]:stimulus is generated :: op1 = %d , op2 = %d , opcode = %d",op1,op2,opcode);
i want to put the messages in the mailbox for all the changes in the inputs.
i .e. i m changing my inputs for every #1 so i want to put these in mailbox.
i have tried like this below code, where my last value is put in the mailbox :
(i’m unable to break the gen task in between to access my mailbox. can we do this ? if so how can this be done)
class generator;
stimulus sti;
mailbox m_box;
function new(mailbox m_box);
this.m_box = m_box;
task run();
repeat(5) begin
sti = new();
sti.gen();
m_box.put(sti);
$display("message is put into mailbox at %g %d",$time,m_box.num());
have u tried by declaring mailbox of stimulus class type? if not please try it and let me know.
In reply to shreebamnikar :
how can i do that ? can you please guide me
dave_59
September 20, 2016, 5:12am
4
*In reply to sreelaxmi : *You should always parameterize your mailbox with the type of item being put/get.
mailbox #(stimulus) m_box;
function new(mailbox #(stimulus) m_box);
this.m_box = m_box;
But this is not your problem. You need to show us what you expect to happen to your inputs and you need to show who does the get(). What you are doing does not make much sense. Normally, your class ‘stimulus’ represents one set of values for (opcode,op1,o2) and create an class object for each set. The each object goes onto the mailbox.
You want something like this?
class stimulus;
logic [2:0]opcode;
//Store messages here
string message;
//Create constructor and pass mailbox
mailbox#(string) msg_mbx;
task gen;
op1 = $random;
op2 = 'd8;
opcode = $random;
op1 = 0;
op2 = $random;
op1 = $random;
op2 = ~op1;
opcode = 3;
op1 = $random;
op2 = $random;
opcode = $random;
endtask //gen
//Store message into mailbox
message = $sformatf("[Stimulus]:stimulus is generated :: op1 = %d , op2 = %d , opcode = %d",op1,op2,opcode);
msg_mbx.put(message);
endtask //stimulus_vectors
endclass //stimulus
In reply to dave_59 :
i’m learning how mailboxes work so as an example i have considered an alu block and by using mailbox im accessing the inputs.
is it right way to do ?
i want to access my mailbox everytime my inputs(opcode op1,op2 ) changes at #1 time .
class driver;
stimulus sti;
mailbox m_box;
//constructor, getting mailbox handle
this.m_box = m_box;
task run;
repeat(5) begin
m_box.get(sti); //getting stimulus from mailbox
$display("Driver:: stimulus is received at %g",$time);
$display("[Driver]:stimulus is generated :: op1 = %d , op2 = %d , opcode = %d %d",sti.op1,sti.op2,sti.opcode,m_box.num());
In reply to mayurkubavat :
class stimulus;
logic [2:0]opcode;
string message;
task gen;
op1 = $random;
op2 = 'd8;
opcode = $random;
op1 = 0;
op2 = $random;
op1 = $random;
op2 = ~op1;
opcode = 3;
op1 = $random;
op2 = $random;
opcode = $random;
endtask //gen
endclass //stimulus
class type doesnot allow string type message
this.m_box = m_box;
stimulus vector is : at 1
[Stimulus]:stimulus is generated :: op1 = 36 , op2 = 8 , opcode = 1
stimulus vector is : at 2
[Stimulus]:stimulus is generated :: op1 = 0 , op2 = 9 , opcode = 2
stimulus vector is : at 3
[Stimulus]:stimulus is generated :: op1 = 99 , op2 = 156 , opcode = 3
stimulus vector is : at 4
[Stimulus]:stimulus is generated :: op1 = 13 , op2 = 141 , opcode = 5
message is put into mailbox at 4 0
Driver:: stimulus is received at 4
[Driver]:stimulus is generated :: op1 = 13 , op2 = 141 , opcode = 5 0
stimulus vector is : at 5
[Stimulus]:stimulus is generated :: op1 = 18 , op2 = 8 , opcode = 1
stimulus vector is : at 6
i want my driver output to work at every #1
then u have to create one diver handle and call driver run task . in initial block like drv.run.
`timescale 1 ns/ 100 ps
//`include "test.sv"
`include "stimulu.sv"
`include "generator.sv"
`include "driver.sv"
module test_top();
generator gen;
mailbox #(stimulus)m_box;
driver dri;
m_box = new();
gen = new(m_box);
dri = new(m_box);
gen.run();
dri.run();
join
#1000 $finish ;
endmodule:test_top
hi,
how can we use mailbox concept between generator module block and driver module block?
my example code is here… please anyone explain me.
module tbtop;
wire clk;
wire [319:0]driver_out;
wire [255:0]pkt1;
reg rst_n;
initial
rst_n = 0 ;
#5ns;
rst_n =1 ;
clkgen cg(.clk(clk));
driver drvr(.clk(clk),.pkt1(pkt1),.driver_out(driver_out));
generator gen(.clk(clk),.pkt1(pkt1));
// clock generator
module clkgen(clk);
output reg clk;
clk = 0;
always #5 clk = ~clk;
// Code your design here
module driver(clk,pkt1,driver_out);
input clk;
// bit trans;
input [255:0]pkt1;
output reg [319:0]driver_out;
bit [15:0]pkt_length;
bit [255:0]ipv4_pkt;
bit [255:0]ipv6_pkt;
bit [255:0]vlan_pkt;
bit [31:0]outcrc1;
bit [1:0]pkt_type;
bit [55:0]preamble ='h5a5a5a5a5a5a5a;
bit [7:0]spd = 'h5d;
reg [319:0]dri_out;
int i;
generator g1();
mailbox mbx = new();
initial begin // trans =1;
g1.gen_pkt(0);
// mbx.get(pkt1);
$display("pkt1=%h",g1.pkt1);
dri_out = {preamble[55:0],spd[7:0],g1.pkt1[255:0]};
$display("dri_out=%0h",dri_out);
for (i=0;i<40;i=i+1) begin
@(posedge clk) driver_out = dri_out[i*8 +: 7];
$display("driver_out=%0h",driver_out);
module generator(clk,pkt1);
input clk;
output reg [255:0]pkt1;
bit[255:0] pkt;
bit[15:0]pkt_length;
bit[255:0]ipv4_pkt;
bit[255:0]ipv6_pkt;
bit[255:0]vlan_pkt;
bit [31:0]outcrc1;
bit [1:0]pkt_type;
//mailbox mbx = new();
// mbx.put(pkt1);
task gen_pkt(input [1:0]pkt_type);
case(pkt_type)
'd0 : begin
pkt_length = 'h256;
for(int i=0; i<256; i++) begin
ipv4_pkt[i*8 +: 7] = $random;
pkt[255:0] ={pkt_length, ipv4_pkt[239:0]};
$display("value of pkt=%0h",pkt);
outcrc1 = gen_crc(pkt_length,pkt);
pkt1[255:0] = {pkt_length, pkt[207:0], outcrc1};
$display("value of pkt1=%0h",pkt1);
'd1 : begin
pkt_length = 'h256;
ipv6_pkt[i*8 +: 7] = $random;
pkt[255:0] = {pkt_length, ipv6_pkt[239:0]};
pkt1[255:0] = { pkt_length,pkt[207:0],outcrc1};
'd2 : begin
pkt_length = 'h256;
vlan_pkt[i*8 +: 7] = $random;
pkt[255:0] = {pkt_length, vlan_pkt[239:0]};
pkt1[255:0] = {pkt_length, pkt[207:0],outcrc1};
endcase
function [31:0] gen_crc(input [15:0]length,input [255:0]pkt);
bit [7:0] d;
bit [31:0] crc, c, temp_crc;
int i;
for (i=0; i<length; i++) begin
d = pkt[i*8 +: 7];
crc[0] = d[6] ^ d[0] ^ c[24] ^ c[30];
crc[1] = d[7] ^ d[6] ^ d[1] ^ d[0] ^ c[24] ^ c[25] ^ c[30] ^ c[31];
crc[2] = d[7] ^ d[6] ^ d[2] ^ d[1] ^ d[0] ^ c[24] ^ c[25] ^ c[26] ^ c[30] ^ c[31];
crc[3] = d[7] ^ d[3] ^ d[2] ^ d[1] ^ c[25] ^ c[26] ^ c[27] ^ c[31];
crc[4] = d[6] ^ d[4] ^ d[3] ^ d[2] ^ d[0] ^ c[24] ^ c[26] ^ c[27] ^ c[28] ^ c[30];
crc[5] = d[7] ^ d[6] ^ d[5] ^ d[4] ^ d[3] ^ d[1] ^ d[0] ^ c[24] ^ c[25] ^ c[27] ^ c[28] ^ c[29] ^ c[30] ^ c[31];
crc[6] = d[7] ^ d[6] ^ d[5] ^ d[4] ^ d[2] ^ d[1] ^ c[25] ^ c[26] ^ c[28] ^ c[29] ^ c[30] ^ c[31];
crc[7] = d[7] ^ d[5] ^ d[3] ^ d[2] ^ d[0] ^ c[24] ^ c[26] ^ c[27] ^ c[29] ^ c[31];
crc[8] = d[4] ^ d[3] ^ d[1] ^ d[0] ^ c[0] ^ c[24] ^ c[25] ^ c[27] ^ c[28];
crc[9] = d[5] ^ d[4] ^ d[2] ^ d[1] ^ c[1] ^ c[25] ^ c[26] ^ c[28] ^ c[29];
crc[10] = d[5] ^ d[3] ^ d[2] ^ d[0] ^ c[2] ^ c[24] ^ c[26] ^ c[27] ^ c[29];
crc[11] = d[4] ^ d[3] ^ d[1] ^ d[0] ^ c[3] ^ c[24] ^ c[25] ^ c[27] ^ c[28];
crc[12] = d[6] ^ d[5] ^ d[4] ^ d[2] ^ d[1] ^ d[0] ^ c[4] ^ c[24] ^ c[25] ^ c[26] ^ c[28] ^ c[29] ^ c[30];
crc[13] = d[7] ^ d[6] ^ d[5] ^ d[3] ^ d[2] ^ d[1] ^ c[5] ^ c[25] ^ c[26] ^ c[27] ^ c[29] ^ c[30] ^ c[31];
crc[14] = d[7] ^ d[6] ^ d[4] ^ d[3] ^ d[2] ^ c[6] ^ c[26] ^ c[27] ^ c[28] ^ c[30] ^ c[31];
crc[15] = d[7] ^ d[5] ^ d[4] ^ d[3] ^ c[7] ^ c[27] ^ c[28] ^ c[29] ^ c[31];
crc[16] = d[5] ^ d[4] ^ d[0] ^ c[8] ^ c[24] ^ c[28] ^ c[29];
crc[17] = d[6] ^ d[5] ^ d[1] ^ c[9] ^ c[25] ^ c[29] ^ c[30];
crc[18] = d[7] ^ d[6] ^ d[2] ^ c[10] ^ c[26] ^ c[30] ^ c[31];
crc[19] = d[7] ^ d[3] ^ c[11] ^ c[27] ^ c[31];
crc[20] = d[4] ^ c[12] ^ c[28];
crc[21] = d[5] ^ c[13] ^ c[29];
crc[22] = d[0] ^ c[14] ^ c[24];
crc[23] = d[6] ^ d[1] ^ d[0] ^ c[15] ^ c[24] ^ c[25] ^ c[30];
crc[24] = d[7] ^ d[2] ^ d[1] ^ c[16] ^ c[25] ^ c[26] ^ c[31];
crc[25] = d[3] ^ d[2] ^ c[17] ^ c[26] ^ c[27];
crc[26] = d[6] ^ d[4] ^ d[3] ^ d[0] ^ c[18] ^ c[24] ^ c[27] ^ c[28] ^ c[30];
crc[27] = d[7] ^ d[5] ^ d[4] ^ d[1] ^ c[19] ^ c[25] ^ c[28] ^ c[29] ^ c[31];
crc[28] = d[6] ^ d[5] ^ d[2] ^ c[20] ^ c[26] ^ c[29] ^ c[30];
crc[29] = d[7] ^ d[6] ^ d[3] ^ c[21] ^ c[27] ^ c[30] ^ c[31];
crc[30] = d[7] ^ d[4] ^ c[22] ^ c[28] ^ c[31];
crc[31] = d[5] ^ c[23] ^ c[29];
$display("the value of CRC result crc = %h",crc);
c = crc;
gen_crc = c;
Sir,
i want to implement mailbox with randomize function.i used to put 10 write data for every 10ns delay but automatic read data to get for every put write data.but output here not put and get 10write and read data same data value is repeated.
//begin
producer.fifo_if.write();
consumer.fifo_if.read();
//end
join
task write();
//a=1;
//fork
int i;
i++;
for(i=0;i<10;i++)begin
#10ns;
fifo_if=new();
void'(fifo_if.randomize());
mbx.put(fifo_if);
$display("write data=%0d",fifo_if);
// #10ns;
// join
task read();
int a;
//if(a===1)
//fifo_if.write=1;
while(1)begin
mbx.get(fifo_if);
$display("read data=%0d",fifo_if);
output
write data=5
read data=5
write data=6
read data=6
write data=5
read data=5
write data=6
read data=6
write data=5
read data=5
write data=6
read data=6
write data=5
read data=5
write data=6
read data=6
write data=5
read data=5
write data=6
read data=6
