Loops in Assertions
I want to loop through a sequence. How can I do that.
for example:
property a;
int no_of_times = 4
disable iff (reset)
@(posedge clk)
 $rose(data) |-> ($rose(clk))[*no_of_times] |-> $fell(data)
Actually Iam waiting for four posedges of clk, after the data rose. But I get compilation errors as shown below
  • ** Error: Range must be bounded by constant expressions
  • ** Error: Left bound of SVA range expression does not evaluate to a constant or parametric value.
  • ** Error: Right bound of SVA range expression does not evaluate to a constant or parametric value.
Can Someone help me out in getting this right? ANd also suggest me if I can use posedge(clk) instead of $rose(clk)? If so, How the code looks like?
I am guessing the behavior you want is for “data” (bit?) to go high, stay high for 3 cycles, and then go low. If so you want to check the whole sequence not just the end case.
You don’t have to call $rose, or posedge clock in the sequence declaration; it’s step delays already reference the clock from the @(posedge clk) code. ##1, etc, are inferred clock cycles.
I haven’t mastered assertion writing, so anyone feel free to verify the following line, but I think you want something more like:
$rose(data) |=> data[*3] ##1 !data
In reply to janudeep3:
property a;
int no_of_times = 4
disable iff (reset)
@(posedge clk)
There are several things wrong with your property:
  1. You declare a local variable and try to use this variable dynamically. In SVA, the delays and repeat operators have to be static.
  2. $rose(data) would work well if data is a single bit, and not a vector.
  3. $rose(clk) interprets “clk” as the signal, and that is sampled in the Preponed region, a delta time just BEFORE the posedge of clk, thus $rose(clk) is always ZERO.
    Below is code that you can simulate.
module mrose;
	int data, numbx=4;
	bit clk, a, b, reset=0, felld, rosed;
	initial forever #10 clk=!clk;
	/* property a;
      int no_of_times = 4
      disable iff (reset)
       @(posedge clk)
    endproperty */
    property a_data;
      // int no_of_times = 4
      disable iff (reset)
       @(posedge clk)
         $rose(data[0]) |-> ##4 $fell(data[0]) // <-- FIXED DELAY
    ap_adata: assert property(a_data);
    property pdata0_v;
      int v;
      disable iff (reset)
       @(posedge clk)
         ($rose(data[0]), v=numbx) |->  // <-- variable delay
               first_match((1, v =v- 1)[*0:$] ##1  v<=0) ##0 $fell(data[0]);
    apdata0_v : assert property(pdata0_v );
    property p_v; // a generic property for
                  // $rose(a) |-> ##w b; // w is a module variable
                  // This in intended to be in 1800'2018
      int v;
      disable iff (reset)
       @(posedge clk)
         ($rose(a), v=numbx) |->
               first_match( (1, v =v- 1)[*0:$] ##1  v<=0 ) ##0 b;
    ap_v : assert property(p_v );
     initial begin   // testbench for the assertions
     repeat(200) begin
       @(posedge clk);
       #1 if (!randomize(data, a, b)  with
           { data dist {2:=1, 5 :=3};
       		 a dist {1'b1:=1, 1'b0:=5};
       		 a dist {1'b1:=1, 1'b0:=2};
       $finish;
  • SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6
HI ben,
Thanks for above explanation. I have one more doubt, Please clarify me.
How the below code works??
($rose(a), v=numbx) |-> ((1, v =v- 1)[*0:$] ##1  v<=0)
// if rose(a) then v gets set to numbx
// in the consequent,  expression "1" is true, and you have a repeat operator.
// Also,
(1, v =v- 1)[*0:$] ##1  v<=0  // is same as
(1, v =v- 1)[*0] ##1  v<=0 // same as v<=0
(1, v =v- 1)[*1] ##1  v<=0
(1, v =v- 1)[*infinity] ##1  v<=0
// and at each cycle, when the consequent fail, v gets decremented.
Another option to have the range be linked to a dynamic module variable is to use the generate statement, which works OK for reasonable max values for the module variable. Example:
   parameter N=2;
   bit clk, a, b, c;
   bit[2:0] v=3;  // Max delay set to 7
   // ap_delay: assert property( $rose(a) |-> ##v b);  // 1800'2018, illegal now
    generate for (genvar g_i=0; g_i<8; g_i++) begin
      ap_delay_gen:  assert property (v==g_i && $rose(a) |-> ##g_i b);
    end endgenerate
How to solve this:
The limitation is that: In SVA, the delays and repeat operators have to be static.So I am looking for an alternative code to replace the “cfg_p_cnt_and_fifo_depth”
variable
property check_interrupts(bit cfg_hb_en,int cfg_p_cnt_and_fifo_depth);
@(posedge clk) disable iff (!arst_n)
cfg_hb_en |-> i_p_dec[0][->cfg_p_cnt_and_fifo_depth] ##1 o_p_halt[0];
endproperty:check_interrupts
Error:
CHECK_INTERRUPTS_PROP: assert property(check_interrupts(cfg_hb_en[0],cfg_p_cnt_and_fifo_depth[0]));
xmelab: *E,NOTPAR (./src/inn_verif_bc_uvm_tb_main_1.0.0/sva/bc_sva.sv,51|93): Illegal operand for constant expression [4(IEEE)].
SVA: sig[->dynamic_var] // goto
 int p1, f1, count=2, dbg;
 bit w, b, clk;
 function automatic void f(); dbg=dbg +1; endfunction
 // b [->m] is equivalent to ( !b [*0:$] ##1 b)[*m]
// m must be static per 1800
 sequence s_goto(bit a, int rpt);
  int v =rpt;
  @(posedge clk)
  (!a[*0:$] ##1 (a, v=v-1'b1, f()))[*1:$] ##0 v<=0;
 endsequence
 ap_test: assert property (@(posedge clk)
              $rose(w) |-> s_goto(b, count)) p1++;
  else f1++;
code Edit code - EDA Playground
wave https://www.edaplayground.com/w/x/79Y
