I have a monitor and a scoreboard connected through uvm_analysis_port/imp. I am sampling some values in the monitor and using the write function to transport those to the scoreboard. The scoreboard is also getting those values as reflected in the info statement and putting it in a queue. However, when I am reading the queue in check_phase, all the entries in the queue have the same value equal to the last value written in the queue. please help debug.
class my_scoreboard extends uvm_scoreboard;
`uvm_component_utils(my_scoreboard)
my_sequence_item tr_q[$];
my_sequence_item tr1;
logic [7:0] prev_a;
logic [7:0] prev_b;
uvm_analysis_imp#(my_sequence_item, my_scoreboard) ai;
function new(string name="scoreboard",uvm_component parent);
super.new(name,parent);
ai=new(name,this);
function void write(my_sequence_item tr_c);
`uvm_info("",$sformatf("writing to queue a-%d, b-%d",tr_c.a,tr_c.b),UVM_LOW); //printing correct values
tr_q.push_back(tr_c);
phase.raise_objection(this);
//write match logic here
phase.drop_objection(this);
function void check_phase(uvm_phase phase);
super.check_phase(phase);
tr1 = my_sequence_item::type_id::create("tr1");
foreach(tr_q[i]) $display(tr_q[i].a); //printing all same values, unintended
while(tr_q.size()) begin
$display("tr_q.size-%d",tr_q.size); //prints correct queue size
tr1=tr_q.pop_front();
if(tr1.doAdd) begin
if(!(tr1.result===(prev_a+prev_b)))
`uvm_info("",$sformatf("add result-%d,a-%d,b-%d",tr1.result,prev_a,prev_b), UVM_LOW);
else begin
if(!(tr1.result===(prev_a-prev_b)))
`uvm_info("",$sformatf("sub result-%d,a-%d,b-%d",tr1.result,prev_a,prev_b), UVM_LOW);
prev_a=tr1.a;
prev_b=tr1.b;
class my_monitor extends uvm_monitor;
`uvm_component_utils(my_monitor)
my_sequence_item tr_m;
virtual add_sub_if vif;
uvm_analysis_port#(my_sequence_item) ap;
function new(string name,uvm_component parent);
ap=new(name,this);
super.build_phase(phase);
//if(!uvm_config_db#(virtual add_sub_if)::get(this,"","add_sub_if",vif))
// `uvm_error("","Error in Monitor");
tr_m=my_sequence_item::type_id::create("tr_m");
forever begin
@(vif.cb);
tr_m.a=vif.a;
tr_m.b=vif.b;
tr_m.doAdd=vif.doAdd;
tr_m.result=vif.cb.result;
ap.write(tr_m);
`uvm_info(get_name(),$sformatf("a-%d, b-%d, doAdd-%d, result-%d",tr_m.a,tr_m.b,tr_m.doAdd,tr_m.result),UVM_LOW);
class my_agent extends uvm_agent;
`uvm_component_utils(my_agent);
my_driver drv;
my_sequencer sqr;
my_monitor mon;
my_scoreboard scbd;
function new(string name="agent", uvm_component parent);
super.new(name, parent);
//build driver, monitor, scoreboard here
drv=my_driver::type_id::create("drv",this);
sqr=my_sequencer::type_id::create("sqr",this);
mon=my_monitor::type_id::create("mon",this);
scbd=my_scoreboard::type_id::create("scbd",this);
`uvm_error(get_name(),"Error getting vif")
//connect driver, sequencer here
drv.seq_item_port.connect(sqr.seq_item_export);
mon.ap.connect(scbd.ai);
drv.vif=this.vif;
mon.vif=this.vif;
endclass: my_agent
Please reply if you need the complete code to help debug.
