Issue of numerous rand variable in constraint
Hi all:
when there are numerous rand variable in constraint:
class xaction;
    rand int num[5];
    constraint c_num {
        foreach (num[i]) {
            if (i > 0 ) {
                num[i-1] < num[i];
            num[i] inside {[0:9]};
endclass : xaction
    xaction x;
    int last_is_9;
    int repeat_num;
        repeat_num = 50000;
        repeat (repeat_num) begin
            x = new;
            x.randomize();
            if (x.num[4] == 9) last_is_9 ++;
       $display("last_is_9 hits: %0d/%0d", last_is_9, repeat_num);
output:
last_is_9 hits: 25260/50000
As we expected, the result in array is uniform distribution, but the posibility of last element x.num[4] is 9 with above 50%.
How to modify the constraint (don’t use user-defined function in post_randomize)can make the x.num[4] inside [4:9] with a reasonable posibility?
Thanks!
If by reasonable you mean you want an even distribution of the values 4-9 in x.num[4], then add a dist constraint.
   constraint c_dist {num[4] dist {[4:9] :=1};}
Thanks for your help!
