I have a packed structure as a rand variable in my sequence item. Is there a way to pack and unpack the entire structure (or structure of structures) using the uvm packing / unpacking macros, without addressing the individual elements?
Madhu
In reply to mseyunni:
Not sure which macros you are referring to.
uvm_packing macros such as uvm_field_in, uvm_field_obj etc
Those are known as the field automation macros and the only handle a limited of data types.
Use SystemVerilog’s bit-streaming cast and the streaming operator to pack/unpack your class members.
