Is it possible to pass a dynamic array through uvm_config_db#(...)::set/get
I looking for a syntax or code example which is passing a dynamic array/queue using the uvm_config_db.
For example, in my “generator component”, I create different kinds of packets to be sent into my DUT.
When one of the packets finished its pass in the DUT, I would like to add one of the output packet fields monitored (e.g. address set by the DUT) to an array. And use the uvm_config_db#(…)::set(…) to configure it in the DB.
So later in the test, I can use the uvm_config_db#(…)::get(…), on this same array of addresses and use it in one of my later packets to read from this address.
Of course, remove/pop it from the array/queue once the packet with this address randomized successfully, and update the uvm_config_db with updated array/queue items left.
Is it possible to pass as a type to uvm_config_db a dynamic array?
If yes, can someone please present a working example?
Thanks in advance,
Michael
In reply to MichaelP:
The uvm_config_db can pass any data type by value. Complex data type like unpacked arrays need typedef, so you would do
uvm_config_db#(my_type)::get(…);
. But if you want to share an array, you need to wrap the array in a class object, then you can use the uvm_config_db to share the handle to that object containing the array.
It seems you want to be pushing and popping address, so a queue would be a better array type, and the UVM already provides a queue wrapped in an object, called
uvm_queue
Thank you very much Dave!!
I have few questions regards the uvm_queue.
  1. I saw in different places over the internet that a uvm_queue can be created either by new():
    class costume_sb extends uvm_scoreboard;
        uvm_queue#(trans_t) txn_queue;
            super.build_phase(phase);
            txn_queue = new();
        endfuction
Or by using the create() method:
   class env extends uvm_env;
      uvm_queue#(string) my_queue;
          my_queue = uvm_queue#(string)::type_id::create("my_queue");
What is the difference between these 2 kinds of creation the uvm_queue?
  1. Regards the uvm_queue methods described in the UVM documentation reference.
    There is one method called: get_global_queue()
    How is it used?
    Is there any good code example and explanation how to use it?
Thanks in advance,
Michael
  1. See this post about new versus create. BTW, only the latest version of the UVM will let you call create() on a UVM base class. Previously, you could only call create() on user defined classes register with the fsctory.
  2. I’d rather not explain things I think are unnecessary.
