module dut ();
input ...
output ...
real voltage;
module test()
wire real dut_volt = dut.voltage;
I am unable to create the net of the type “real” which I guess is the only Floating point representation data type available in SV.
Error also reads - Net data types can only be composed of 4-state integral types, enum with 4-state base type, structure, union, and fixed-size arrays.
I understand that real is a 2-bit data type, but I don’t know how to fix the issue ?
With what you have shown, you don’t need a wire. You can use a continuous assignment to a variable of any type, as long as there is only one continuous assignment driving the variable.
module test()
real dut_volt;
assign dut_volt = dut.voltage;
If you need multiple drivers to the same signal, then you have to use a wire and a wire with anything beyond an integral data type needs a special declaration. See 6.7.2 Net declarations with user-defined nettypes in the 1800-2012 LRM for more information.
I did refer the section that you have mentioned, but I was unable to understand how to use a user-defined datatype. It would be really helpful if you could provide me a link to an example.
I believe that I need to do that to address my issue completely.
And also,
“If you need multiple drivers to the same signal, then you have to use a wire” - Do you mean to say if dut.voltage is used by more signals other than just dut_volt ?
If yes, I will need to understand how to do the special declaration!
In reply to Bhaskar44:
When I say multiple drivers, I mean multiple concurrent continuous assignments to the same signal(dut_volt). Then dut_volt would have to be declared as a wire with a nettype.
For performance reasons, many tools have predefined packages that you can import that have resolution functions to take the min, max, or sum of all the real drivers on a signal. You will have to look it up the user manual of the tool you are using.
