Interface direct connection at top level
What is the right sintax to connect interface signals as single at the top level?
I’ve created an example to ilustrate what i’d like to do that does not work.
Just at the top level of a module (exceptional case), I would like to be able to connect single interface lines as single:
.interfaz.b (driv)
but that does not work.
What would be the right syntax to do this?
Example code:
interface myitf (input bit b);
	byte a;
endinterface
module mymodule (myitf interfaz);
    interfaz.a = 7;
    $display("*** [info] my module interfaz.b = %b, interfaz.a = %d",interfaz.b, interfaz.a);
module mytb();
  // --- this works
  logic driv = 1'b1;
  myitf dummyitf(.b(driv));
  mymodule okmod (
    .interfaz (dummyitf)
  // --- this does NOT work
  mymodule notokmod (
    .interfaz.b (driv)
Thank you for the help you can provide
In reply to stefaniemcg:
What you are asking cannot be done. This is an XY Problem.
