Interface class polymorphism
Hi SystemVerilog forum.
I am trying to use polymorphism to make the code easier.
The following code works but I don’t want to use it
interface class inter;
   pure virtual function void print();
endclass: inter
class private_name implements inter;
   virtual function void print;
      $display("Shimon");
   endfunction: print
endclass: private_name
class last_name implements inter;
      $display("Cohen");
   endfunction: print
endclass: last_name
class name;
   private_name pname;
   last_name lname;
      function void print_person();
         pname = new();
	 lname = new();
	 pname.print();
	 lname.print();
     endfunction: print_person
   name m_name = new();
      m_name.print_person();
In the following code I placed private_name and last name in an array of type inter.
Obviously it won’t work because inter cant be instantiated. how can I $cast this structure?
I need this structure because In my project I going to add many classes that implements inter, and all I want to do is to
add the name of the new class in the array.
class name;
   inter m_inter[]={private_name, last_name};
      foreach(m_inter[i]) begin
         m_inter[i] = new();
         m_inter[i].print();
In reply to shimonc:
A simple solution is delegating construction to a static method
class wrapper #(type T);
   static function inter create;
      T obj = new;
      return obj;
class name;
   inter m_inter[]= {wrapper#(private_name)::create, wrapper#(last_name)::create};
      foreach (m_inter[i])
         m_inter[i].print();
There are other ways of doing this involving factory proxy classes depending on what you are ultimately thinking about. See the links here.
Great solution thanks.
I need to model to analog behavior of IP phone, network camera, access point etc.
many classes are involved in this models.
I investigate the “Design Patterns: Elements of Reusable Object-Oriented Software” topic in order to build the model correctly.
If you have suggestions or papers on how to correctly build these kind of models it will help allot.
small anecdote about the links
I am the one that found the typo in “OOP Design Pattern Examples” :-)
