Hi All,
I want to make an UVM environment of Dual Port RAM.As Design of Dual port RAM contains bi-directional data signal I have defined internal reg and then assign value of this reg to inout signal.Here is my interface and driver of code:
1)Interface Code:
interface dpram_if(input logic clk);
wire [7:0] data_0;
wire [7:0] data_1;
logic [7:0] data0;
logic [7:0] data1;
logic [7:0] address_0;
logic cs_0;
logic we_0;
logic oe_0;
logic [7:0] address_1;
logic cs_1;
logic we_1;
logic oe_1;
always@(posedge clk) begin
if(we_0)
force tbench_top.DUT.data_0 = data0;
release tbench_top.DUT.data_0;
if(we_1)
force tbench_top.DUT.data_1 = data1;
release tbench_top.DUT.data_1;
modport DRIVER (output address_0,cs_0,we_0,oe_0,address_1,cs_1,we_1,oe_1,data0,data1,input clk,inout data_0,data_1);
modport MONITOR (input address_0,cs_0,we_0,oe_0,address_1,cs_1,we_1,oe_1,data_0,data_1,data0,data1,clk);
endinterface:dpram_if
- Driver Code:
`define DRV_IF vif.DRIVER
class dpram_driver extends uvm_driver #(dpram_seq_item);
virtual dpram_if vif;
`uvm_component_utils(dpram_driver)
function new(string name = "dpram_driver",uvm_component parent);
super.new(name,parent);
endfunction:new
super.build_phase(phase);
if(!uvm_config_db#(virtual dpram_if)::get(this,"","vif",vif))
`uvm_fatal("NO_VIF",{"virtual interface must be set for:",get_full_name(),".vif"});
endfunction:build_phase
dpram_seq_item req_rand;
forever begin
seq_item_port.get_next_item(req_rand);
`DRV_IF.data_0 = req_rand.we_0 ? req_rand.data0 : 8'bz;
`DRV_IF.data_1 = req_rand.we_1 ? req_rand.data1 : 8'bz;
@(posedge vif.clk);
`DRV_IF.address_0 = req_rand.address_0;
`DRV_IF.cs_0 = req_rand.cs_0;
`DRV_IF.we_0 = req_rand.we_0;
`DRV_IF.oe_0 = req_rand.oe_0;
`DRV_IF.data0 = req_rand.data0;
`DRV_IF.address_1 = req_rand.address_1;
`DRV_IF.cs_1 = req_rand.cs_1;
`DRV_IF.we_1 = req_rand.we_1;
`DRV_IF.oe_1 = req_rand.oe_1;
`DRV_IF.data1 = req_rand.data1;
seq_item_port.item_done();
$display("Here are the randomized values at driver\n");
req_rand.print();
$display("Value of data_0 = %0h",`DRV_IF.data_0);
$display("Value of data_0 = %0h",req_rand.data0);
endtask:run_phase
endclass:dpram_driver
Here,The internal reg data0 and data1 are randomized but the value of data0 and data2 is not assigned to inout signal(Which are data_0 and data_1).Also there is no interface value come on monitor.
