Hi All,
Here is the below code:
module p1;
class parent;
rand bit [3:0] sa,da,payload[8];
bit [3:0] crc;
function void cal_crc;
crc = (sa ^ da ^ payload.xor);
$display("parent: CRC output %0d",crc);
$display("sa %0d da %0d",sa,da);
class child extends parent;
rand bit error;
super.cal_crc();
if (error) begin
crc = ~crc;
$display("child : CRC output %0d",crc);
child c1;
c1 = new;
repeat (1) begin
c1.randomize();
c1.cal_crc();
output of the code
parent: CRC output 0
sa 3 da 14
child : CRC output 8
If error is set, then parent crc should be complement.
Lets say if crc is 'h01, complement of this must be 'hFE.
but parent crc is always zero, I am not able to see non zero value of crc in parent class.
I could not understand the issue, may I know the reason?
Thank You,
