I have a doubt in the following implementation:
class parent_class;
bit [31:0] addr;
bit [31:0] data;
function new();
addr= 'hffff;
data = 'h5555;
task display();
$display("Base Addr = %h and data %h",addr,data);
class child_class extends parent_class;
bit [31:0] data;
bit [31:0] addr;
function new();
addr='h8888;
data = 'h1234;
task display();
super.display();
$display("Ext Data = %h, addr = %h", addr,data);
module inheritence;
child_class c;
parent_class b;
b =new();
c= new();
$display("%p", c);
c.display();
Output:
‘{super:’{addr:'hffff, data:'h5555}, data:'h1234, addr:'h8888}
Base Addr = 0000ffff and data 00005555
Ext Data = 00008888, addr = 00001234
Why does the addr and data values from the base class used in super.display() which is called from extended class?
Whereas if I overwrite the value of addr and data in the extended class, without explicitly declaring addr and data, then extended class values are printed using super.display() function. The code is as follows:
class parent_class;
bit [31:0] addr;
bit [31:0] data;
function new();
addr= 'hffff;
data = 'h5555;
task display();
function new();
addr='h8888;
data = 'h1234;
task display();
super.display();
module inheritence;
child_class c;
parent_class b;
b =new();
c= new();
$display("%p", c);
c.display();
Output:
‘{super:’{addr:'h8888, data:'h1234}}
Base Addr = 00008888 and data 00001234
Sakshi
