Imported C-DPI task(which internally calls exported SV tasks) getting disabled.Please help
Hello everyone,
I have imported following C subroutine(RunTestCase) to SV as follows.
import “DPI-C” context RunTestCase = task RunTestCase(int TestcaseId);
Inside the C code , it calls the SV tasks exported from SV domain to C domain.
C code looks like this…
extern “C” int RunTestCase (int TestId) {
…some code
…some code…
WriteField(“something”,“REG_something”,“something”,255); //This is exported from SV
WriteField is declared as follows in SV file
export “DPI-C” WriteField = task WriteField;
task WriteField (input string block_name, input string reg_name, input string field_name, input int Data);
…some code
Everything looks correct here.
But I am getting following error.
xmsim: *F,DISEXP: The export subroutine WriteField cannot be called from disabled import subroutine RunTestCase.
The question is , why subroutine “RunTestCase” is getting disabled. I never did that manually in code.!!
Please help. Its urgent.
Suyog
+91 9845696897
In reply to suyog_asic:
Hard to say without seeing more code. Did you follow the protocol for DPI exports in section 35.9 Disabling DPI tasks and functions in the 1800-2017 LRM?
Hi Suyog,
I am facing the same issue currently. Could you post the solution for the problem if you were able to fix it?
Thank you.
In reply to SrikarChoppakatla:
Hi ,
The C-dpi task was actually getting disabled due to all objections getting dropped.
Even whenever I saw this issue with some of my collegues, the reason was imported task(task consumes non zero time as u know) was getting called from SV domain and there was no objection raised , so imported task was getting disabled.
Basically as the error says, the C-DPI task was actually getting disabled( due to some reason…one reason may be objections dropped).
Suyog
