task my_check(bit [19:0] addr, bit [31:0] expect_data, int shift, int width);
bit [31:0] my_data;
int msb = shift+width-1;
int lsb = shift;
my_env.my_ral_mdl.read(status, value, UVM_BACKDOOR); // use ral backdoor method to read register
my_data = value[msb:lsb];
but hit below error.
Error-[IRIPS] Illegal range in part select
The range of the part select is illegal:
Unknown range in part select.this.value[msb:lsb]
Variable slicing is not allowed in sv bit locations have to be constant. Of you explain what you are planning to achieve maybe we could give a fix.
If you are just planning to compare exp_data with data you do not need to slice it. Anyway woth regards of register access usually fields are compared eachother so it might depend on the result you are trying to get.
Do you wanna compare fields? Do you wanna compare just random bits? Regards
everytime when we call this task the shift and width are changed. anyway, I use the original method to make it pass. thanks everyone for your great help
module tb;
int splitbit;
bit [35:0] address = 35'h123456789;
bit [35:0] arranged_addr;
splitbit = $urandom_range(1, 31);
$display("SPLITBIT=%0d", splitbit);
arranged_addr[35:31] = address[(splitbit+4) -: 5];
arranged_addr[30:0] = {address[35 : (splitbit + 5)], address[(splitbit - 1) : 0]};
$display("arranged_addr=%b",arranged_addr);
My requirement is that the splitbit signal in this code randomly range from 1 to 31. and I’m rearranging address bits based on the splitbit value. since I wish to move five bits from the splitbit value in the arranged_addr’s MSB. if the splibit value is randomized to 10 then, arranged_addr[35:31] = address[14:10] and arranged_addr[30:0] = {address[35:15], address[9:0]} .
