When using the DPI-C function, can I call and use the function inside the package?
My example is <dip_c.h>
##include <svdpi.h>
extern int reg_read(int addr, int data);
int my_seq(int addr, int data);
<dip_c.c>
int my_seq(int addr, int data){
reg_read(addr,data);
<package_a.sv>
package A;
import "DPI-C" context task my_seq(input int addr, input int data);
export "DPI-C" task reg_read;
my_agent global_agent;
task reg_read(input int addr, output int data);
if(global_agent != null) begin
global_agent.cpu_read32(addr,data);
else begin
$display("Error: global_agent is null");
endtask : reg_read
endpackage : A
<package_b.sv>
package B;
import A::*;
`include "my_other_code.sv"
endpackage : B
You code does not show who calls the DPI imported task my_seq. SystemVerilog distinguishes tasks from functions by allowing to consume simulated time. C has no concept of simulated time, but the DPI places the same restrictions that “functions” must not consume time. The only way a C-imported task consumes time is by calling a SV-exported task.
One of the complexities when a process consumes time is the possibility for some other process to disable or kill it. Thr DPI handles that using the return value of a C task. See section 35.9 Disabling DPI tasks and functions in the LRM. Your code may need to deal with that.
