Hi
I want to set a DUT’s signal with a default value without agent instantiation. I want to assign all variables that drive the agent to 1’b0 if the agent is not required for that particular test. Which is the recommended way to do that?
Thanks!
In reply to kevinvig7:
Will you still instantiate the agent’s interface in your testbench? If so, you can use a ‘mode’ variable in the interface which you can use to determine whether to drive the interface outputs from internal variables or idle states.
interface my_if;
// Wires to connect to design
wire my_if_a_wire;
// Internal variables to be driven by agent
reg my_if_a_reg;
bit mode = 0; // 0 if idle, 1 if active
assign my_if_a_wire = (mode == 0) ? 1'b0 : my_if_a_reg;
endinterface
If you don’t instantiate the interface, you will need to assign the signals directly in your testbench.
In reply to cgales:
It makes sense! Thanks! I will Try
