module xyz;
bit [9:0] sel;
bit [1:0] dev;
for(sel=0;sel<=9;sel++)
if(sel==0 || sel==5) $display("sel==%b",sel);
for(dev=0;dev<=3;dev++)
$display("dev=%b , sel==%b",dev,sel);
In reply to prafulborad3@gmail.com:
dev is 2-bits and cannot be greater than 3.
okay…
i know dev value are between 0 to 3
and i dont want the value of dev is greater than 3
but i don’t understand the reason of infinite loop.
Can you explain how you think it should get out of the loop?
In reply to avpchandra:
Don’t need to. As Dave said, the problem because dev was declared 2 bits. To exit the for loop “for(dev=0;dev<=3;dev++)”, the value of dev must > 3, this will never happen when you declared dev 2 bits, value of dev: 0 - 1 - 2 - 3 - 0, and so on.
