I am doing uvm adder varification but i have got some error
class seq_item extends uvm_sequence_item;
`uvm_object_utils(seq_item)
rand bit [1:0]a;
rand bit [1:0]b;
rand bit c;
bit [2:0]sum;
 function new(string name="seq_item");
	 super.new(name);
import uvm_pkg::uvm_sequence;
class base_seq extends uvm_sequence#(seq_item);
seq_item tx;
`uvm_object_utils(base_seq)
function new(string name=“base_seq”);
super.new(name);
task body();
  repeat(2) begin
   tx=seq_item::type_id::create("tx",this);
   start_item(tx);
    assert(tx.randomize);
    tx.print();
   finish_item(tx);
class sequencer extends uvm_sequencer#(seq_item);
 `uvm_component_utils(sequencer)
 function new(string name,uvm_component parent);
     super.new(name,parent);
class driver extends uvm_driver#(seq_item);
seq_item tx;
virtual intf vif;
 `uvm_component_utils(driver)
void’(uvm_config_db #(virtual intf)::get(this,“”,“pif”,vif));
     forever begin
         seq_item_port.get_next_item(tx);
            vif.a=tx.a;
            vif.b=tx.b;
            vif.c=tx.c;
            @(negedge vif.clk);
         seq_item_port.item_done();
class monitor extends uvm_monitor;
virtual intf vif;
seq_item tx;
uvm_analysis_port#(seq_item) port;
`uvm_component_utils(monitor)
void’(uvm_config_db#(virtual intf)::get(this,“”,“pif”,vif));
port=new(“port”,this);
tx=seq_item::type_id::create(“tx”,this);
forever begin
@(posedge vif.clk);
tx.a=vif.a;
tx.b=vif.b;
tx.c=vif.c;
tx.sum=vif.sum;
port.write(tx);
class agent extends uvm_agent;
sequencer sqr;
driver dvr;
monitor mon;
`uvm_component_utils(agent)
     sqr=sequencer::type_id::create("sqr",this);
     dvr=driver::type_id::create("dvr",this);
     mon=monitor::type_id::create("mon",this);
     dvr.seq_item_port.connect(sqr.seq_item_export);
class scoreboard extends uvm_scoreboard;
seq_item tx;
uvm_analysis_imp#(seq_item,scoreboard) imp;
bit [4:0]sum;
`uvm_component_utils(scoreboard)
imp=new(“imp”,this);
function void write(seq_item tx1);
this.tx=tx1;
   sum=tx.a + tx.b +tx.c;
    if(sum == tx.sum)
  		$display( "Result match","tx.sum=%0d & sum=%0d ",tx.sum,sum);
  		$display( "Result misMatch","tx.sum=%0d &  sum=%0d ",tx.sum,sum);
class env extends uvm_env;
agent agent1;
scoreboard sb;
 `uvm_component_utils(env)
     agent1=agent::type_id::create("agent1",this);
     sb=scoreboard::type_id::create("sb",this);
         agent1.mon.port.connect(sb.imp);
class base_test extends uvm_test;
env env1;
base_seq seq;
 `uvm_component_utils(base_test)
     env1=env::type_id::create("env1",this);
           seq=base_seq::type_id::create("seq",this);
   phase.raise_objection(this);
    seq.start(env1.agent1.sqr);
   phase.drop_objection(this);
include "uvm_pkg.sv" include “uvm_macros.svh”
import uvm_pkg::*;
include "interface.sv" include “dut.sv”
include "seqitem.sv" include “sequence.sv”
include "driver.sv" include “monitor.sv”
include "sequencer.sv" include “agent.sv”
include "scoreboard.sv" include “env.sv”
`include “test.sv”
bit clk;
intf pif(clk);
adder dut(pif);
uvm_config_db#(virtual intf)::set(uvm_root::get(),“*”,“pif”,pif);
run_test(“base_test”);
clk=0;
forever #5 clk=~clk;
I have got 2 errors and 9 warning
** Error: (vsim-7065) Illegal assignment to class work.uvm_pkg::uvm_component from class work.top_sv_unit::base_seq
Time: 0 ns Iteration: 0 Region: /top_sv_unit::base_seq File: sequence.sv Line: 14
** Error: (vsim-8754) Actual input arg. of type ‘class work.top_sv_unit::base_seq’ for formal ‘parent’ of ‘create’ is not compatible with the formal’s type ‘class work.uvm_pkg::uvm_component’.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_get_next_arg_c’ in DPI C/C++ source files.
Time: 0 ns Iteration: 0 Region: /uvm_pkg File: /tools/questa-/2020.3/questasim/uvm-1.1d/…/verilog_src/uvm-1.1d/src/uvm_pkg.sv
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_get_tool_name_c’ in DPI C/C++ source files.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_get_tool_version_c’ in DPI C/C++ source files.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_regcomp’ in DPI C/C++ source files.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_regexec’ in DPI C/C++ source files.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_regfree’ in DPI C/C++ source files.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dump_re_cache’ in DPI C/C++ source files.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_glob_to_re’ in DPI C/C++ source files.
Error loading design
End time: 09:32:17 on Jul 14,2021, Elapsed time: 0:00:23
Errors: 2, Warnings: 9
please tell where is it comming and why
In reply to taufeeq_khan:
Seems like some simulator related issue?
i have modified your code a bit, this might help you.
tx=seq_item::type_id::create(“tx”,this); → sequence_item takes only name as argument
import uvm_pkg::*;
`include "uvm_macros.svh"
rand bit [1:0]a;
rand bit [1:0]b;
rand bit c;
bit [2:0]sum;
super.new(name);
seq_item tx;
function new(string name="base_seq");
super.new(name);
task body();
repeat(2) begin
tx=seq_item::type_id::create("tx");
start_item(tx);
tx.print();
finish_item(tx);
seq_item tx;
virtual intf vif;
void'(uvm_config_db #(virtual intf)::get(this,"","pif",vif));
forever begin
@(posedge vif.clk);
vif.a=tx.a;
vif.b=tx.b;
vif.c=tx.c;
virtual intf vif;
seq_item tx;
void'(uvm_config_db#(virtual intf)::get(this,"","pif",vif));
port=new("port",this);
forever begin
@(posedge vif.clk);
tx.a=vif.a;
tx.b=vif.b;
tx.c=vif.c;
tx.sum=vif.sum;
port.write(tx);
sequencer sqr;
driver dvr;
monitor mon;
seq_item tx;
bit [4:0]sum;
imp=new("imp",this);
this.tx=tx1;
if(sum == tx.sum)
agent agent1;
scoreboard sb;
env env1;
base_seq seq;
interface intf(input bit clk);
logic [1:0]a,b;
logic c;
logic [2:0]sum;
endinterface
module adder(intf vif);
//always @(posedge vif.clk)
//begin
assign vif.sum=vif.a+vif.b+vif.c;
//end
bit clk;
intf pif(clk);
adder dut(pif);
uvm_config_db#(virtual intf)::set(uvm_root::get(),"*","pif",pif);
run_test("base_test");
clk=0;
In reply to vardhana:
This line will be the cause of your error:
Please correct to
seq=base_seq::type_id::create("seq");
Please correct to
Yea, right. i didnot check that.
but was wondering, why the simulator didnot throw any error?
thanks for reply
now this error is comming
Fatal: (vsim-160) /tools/questa-/2020.3/questasim/uvm-1.1d/…/verilog_src/uvm-1.1d/src/dpi/uvm_svcmd_dpi.svh(27): Null foreign function pointer encountered when calling ‘uvm_dpi_get_next_arg_c’
Time: 0 ns Iteration: 0 Process: /uvm_pkg/#INITIAL#619 File: /tools/questa-/2020.3/questasim/uvm-1.1d/…/verilog_src/uvm-1.1d/src/dpi/uvm_svcmd_dpi.svh
Fatal error in Module uvm_pkg at /tools/questa-/2020.3/questasim/uvm-1.1d/…/verilog_src/uvm-1.1d/src/dpi/uvm_svcmd_dpi.svh line 27
HDL call sequence:
Stopped at /tools/questa-/2020.3/questasim/uvm-1.1d/…/verilog_src/uvm-1.1d/src/dpi/uvm_svcmd_dpi.svh 27 Module uvm_pkg
called from /tools/questa-/2020.3/questasim/uvm-1.1d/…/verilog_src/uvm-1.1d/src/dpi/uvm_svcmd_dpi.svh 32 Module uvm_pkg
called from /tools/questa-/2020.3/questasim/uvm-1.1d/…/verilog_src/uvm-1.1d/src/base/uvm_cmdline_processor.svh 245 Function uvm_pkg/uvm_cmdline_processor::new
called from /tools/questa-/2020.3/questasim/uvm-1.1d/…/verilog_src/uvm-1.1d/src/base/uvm_cmdline_processor.svh 61 Function uvm_pkg/uvm_cmdline_processor::get_inst
thank
now it is runing
why it iss giving one mismatch value
Result misMatchtx.sum=0 & sum=2 tx.a=1 tx.b=1 tx.c=0
Name Type Size Value
tx seq_item - @696
begin_time time 64 10
depth int 32 'd2
parent sequence (name) string 3 seq
parent sequence (full name) string 32 uvm_test_top.env1.agent1.sqr.seq
sequencer string 28 uvm_test_top.env1.agent1.sqr
Result matchtx.sum=0 & sum=0 tx.a=0 tx.b=0 tx.c=0
tx seq_item - @700
begin_time time 64 20
depth int 32 'd2
tx seq_item - @704
begin_time time 64 30
depth int 32 'd2
Result matchtx.sum=2 & sum=2 tx.a=1 tx.b=1 tx.c=0
UVM_INFO verilog_src/uvm-1.0p1/src/base/uvm_objection.svh(1116) @ 40: reporter [TEST_DONE] ‘run’ phase is ready to proceed to the ‘extract’ phase
— UVM Report Summary —
** Report counts by severity
UVM_INFO : 2
UVM_WARNING : 0
UVM_ERROR : 0
UVM_FATAL : 0
** Report counts by id
[RNTST] 1
[TEST_DONE] 1
** Note: $finish : C:/questasim_10.0b/win32/…/verilog_src/uvm-1.0p1/src/base/uvm_root.svh(392)
Time: 40 ns Iteration: 50 Instance: /top
1
thank
now it is runing
tx seq_item - @696
depth int 32 'd2
tx seq_item - @700
depth int 32 'd2
tx seq_item - @704
depth int 32 'd2
UVM_INFO : 2
UVM_WARNING : 0
UVM_ERROR : 0
UVM_FATAL : 0
[RNTST] 1
[TEST_DONE] 1
1
UVM_INFO @ 0: reporter [RNTST] Running test base_test…
tx seq_item - @3729
begin_time time 64 5
depth int 32 'd2
Result matchtx.sum=3 & sum=3
tx seq_item - @3777
begin_time time 64 15
depth int 32 'd2
Result matchtx.sum=4 & sum=4
tx seq_item - @3792
begin_time time 64 25
depth int 32 'd2
tx seq_item - @3752
begin_time time 64 35
depth int 32 'd2
Result matchtx.sum=5 & sum=5
tx seq_item - @3702
begin_time time 64 45
depth int 32 'd2
can you post you dut ?
dut
module adder(intf pif);
always@(posedge pif.clk)
	   pif.sum=pif.a + pif.b + pif.c;
