I am trying to create a function in order to find the ral path instead every user trying to remember or type the big ral path
i.e
find_ral_path_reg(input string block, input string reg_name);
Typical path of a reg of specific block is the below
m_tb_env.m_Ral2.ial_tc_bbs.DVSEC_FBRANGE1HIGH where the DVSEC_FBRANGE1HIGH is the register
If I create a uvm_reg var i.e csr_name and I assign the full above path the
m_tb_env.m_Ral2.ial_tc_bbs.DVSEC_FBRANGE1HIGH where the DVSEC_FBRANGE1HIGH.write works. I do see the handler being retrieved
Now I will try to find the handler using the find_ral_path_reg based on the two input arguments
Inside the code I have
csr_name = m_tb_env.m_Ral2.ial_tc_bbs.BBS_PATH(reg_name) The macro is defined as define BBS_PATH(reg) reg
It seems the reg_name can not be evaluated just before the macro as DVSEC_FBRANGE1HIGH
so I am getting the reg_name
Is there a way to evaluate the register name from the input function during the macro call?
In reply to george7272:
I am not following what your problem is, or what you are even trying to do. The macro
`define BBS_PATH(reg) reg
does not do anything. I just passes its argument as if the macro was never there. `BBS_PATH(XYZ) would just be replaced with XYZ.
Hi Dave
The issue is that the argument as you pointed out the XYZ is an argument in a function
The argument is not evaluated before it goes to the macro
Let’s call the function and the reg_name le’ts make it uvm_reg type)
uvm_reg csr;
csr=find_ral_path_reg(BBS,DVSEC_FBRANGE1HIGH);
I should get as csr the following
If I call the functions passing a different register name i.e
csr=find_ral_path_reg(BBS,DVSEC_FBRANGE1HIGH5); I should get as csr
m_tb_env.m_Ral2.ial_tc_bbs.DVSEC_FBRANGE1HIGH5
but I am not getting that
I am always getting
m_tb_env.m_Ral2.ial_tc_bbs.reg
I am getting the name I use as an argument to the macro
Is there a way the macro argument to be evaluated to whatever is being passed in the function?
Macros are preprocessing text compiler directives that get expanded before any SystemVerilog code gets parsed.
What is BBS? You cannot covert a string to an identifier name.
The is a uvm_reg_block method called get_reg_by_name and get_field_by_name. Maybe that is what you really need instead of what you are trying to do.
