In UVM we directly use phases to do different things. But how simulator understands from uvm base library that it need to start with build_phase and after that need to execute connect_phase and so on …
Till now I just got this info but don’t understand how it actually works. Could anyone help me understand summarizing underlying mechanism ?
The simulator understands UVM because ir is written in SystemVerilog. The phasing is taking advantage of virtual methods and building lists of “Component” classes and simply iterating over that list for each phase. Below is a very simplified example showing the structures the UVM creates and how it executes them:
class Component;
string m_name;
Component m_parent;
static Component list[$];
function new(string name, Component parent);
m_name = name;
m_parent = parent;
list.push_back(this);
function string get_fullname;
if (m_parent == null)
return m_name;
return {m_parent.get_fullname(), "." , m_name};
virtual function void build_phase;
virtual task run_phase;
virtual function void report_phase();
class A extends Component;
super.new(name,parent);
$display("A Constructing: ", get_fullname);
task run_phase;
#10 $display("Running from ",get_fullname(),,$time);
function void report_phase;
$display("Reporting from ",get_fullname(),,$time);
class B extends Component;
$display("B Constructing: ", get_fullname);
A a;
a = new("a",this);
task run_phase;
#20 $display("Running from ",get_fullname(),,$time);
class Root extends Component;
$display("env Constructing: ", get_fullname);
A a;
B b;
a = new("a",this);
b = new("b",this);
task run_test;
// build_phase
for(int item=0;item<list.size();item++)
list[item].build_phase();
// run_phase
foreach(list[item])
int k = item;
list[k].run_phase();
join_none
wait fork;
// report phase
foreach(list[item])
list[item].report_phase();
Root root;
root =new("root",null);
root.run_test();
