How use interface in verification of a module that has not use interface?
I want to do standard verification for a module.
It is not used interface in this module and it has a lot of inputs and outputs.
what is the best way to use the interface in the testbench?
You just break out the interface signals in the DUT instantiation
e.g. below the slave signals are connected to a Slave interface
and the master signals are ocnnected to a Master interface
switch DUT(.clk(clk),
.rst(rst),
.slv_din(SB_rhs_agent_bus.slv_din),
.slv_din_en(SB_rhs_agent_bus.slv_din_en),
.slv_dout(SB_rhs_agent_bus.slv_dout),
.slv_dout_en(SB_rhs_agent_bus.slv_dout_en),
.mstr_din(SB_lhs_agent_bus.mstr_din),
.mstr_din_en(SB_lhs_agent_bus.mstr_din_en),
.mstr_dout(SB_lhs_agent_bus.mstr_dout),
.mstr_dout_en(SB_lhs_agent_bus.mstr_dout_en)
