How to wait on a clocking block signal with timeout functionality
When I have to wait for signal, I usually use statement like @(cb iff signal == condition)
However, the issue in such statement is that the if the clocking block keeps waiting then it is harder to trace back. Therefore, I end up using while loop with clock cycles threshold for the ease for debug but this increases verbosity. Such as
while(!condition) begin
@(cb);
if(cycle count)
FATAL;
Therefore, is there anyway where I can add timeout condition in clocking block , for example, @(cb iff signal with timeout)?
check this, I have use simple clk, but you can use clocking block as well.
Juhi Patel.
https://www.linkedin.com/in/juhi-patel-455535149/
In reply to Juhi_Patel:
Not exactly sure what you need to do, but you could try
  @(cb iff signal == condition);
  wait(cycle_cout == something);
join_any
disable fork; // gets rid of other hanging threads
if (cycle_cout == something)
   // then you timed out;
   // otherwise you didn't
Hey Juhi,
rather than assigning value to B, you can also wait for A==15 in fork and that would work fine right. just trying to use less variables and always code block.
thanks
In reply to Blitzz0418:
Yes sure, you’re correct. But i just wanted to give one example and i had idea that b always goes high when a value is reaching to 15 and busy waiting is done on b.
Juhi Patel.
join_any
This is how I have been using in my simulations and it works well. Thank you.
