How to use numbered identifiers in a loop
Let’s say I want to connect a bus, similar to the below, where the name of the wire includes numbering:
wire bus[500:0];
assign bus[0] = my_wire_0;
assign bus[1] = my_wire_1;
assign bus[500]= my_wire_500;
Is there a way to do this in a loop (generate or otherwise)? Especially interesting if the width is a parameter and not a constant.
My attempts have failed as:
  1. I couldn’t modify the wire name identifier at the correct part of the process
  2. I tried using concatenation using macros (``), but macro elaboration is done before the loop unrolling and thus fails.
In reply to vlsiraptor:
I don’t believe you can do this directly in Verilog/SV (Unless Dave decides to surprise me and teach me one more today :-)). However, a simple pre-processor can do this:
module m();
  wire bus[500:0];
  //@ for my $i (0..500) {
  assign bus[$i] = my_wire_$i;
endmodule : m
Then use the vpp.pl from: http://www.beyond-circuits.com/wordpress/vpp-pl-man-page/
I used it like:
perl vpp.pl inp_with_meta.v -perl
Sample output (Of-course not showing 501 lines :-) )
module m();
  wire bus[500:0];
  assign bus[2] = my_wire_2;
  assign bus[3] = my_wire_3;
  assign bus[4] = my_wire_4;
  assign bus[5] = my_wire_5;
HTH
Srini
www.verifworks.com
