I am trying to set and get array of interfaces using config_db. I am able use generate method to set the interfaces but how do I get the interfaces?
module abc();
ram_if intf[3](clk, rst_n);
generate
for (genvar i=0; i< 3; i++)begin
uvm_config_db#(virtual ram_if)::set(null, "*", "vif", intf[i]);
endgenerate
//uvm env class - build_phase
virtual ram_if vif[3];
super.build_phase(phase);
if(!uvm_config_db#(virtual ram_if)::get(this, "", "vif", vif)) //Error on this line
`uvm_fatal(get_type_name, $sformatf("Did not receive ram_if"))
Error-[ICTTFC] Incompatible complex type usage
testbench.sv, 191
Incompatible complex type usage in task or function call.
The following expression is incompatible with the formal parameter of the
function. The type of the actual is 'virtual interface ram_if$[0:2]', while
the type of the formal is 'virtual interface ram_if'. Expression: this.vif
Source info: uvm_config_db#(ram_if)::get(this, "\000", "vif", this.vif)
In reply to UVM_SV_101:
You are using the same name (“vif”) for all instances. You want to create unique names for each instance in the set() and get() calls.
Do you know the reason why for loop cannot be used when using config_db set method?
Interfaces are design level constructs which imposes some limitations on how you can index them using variables.
However, virtual interfaces are verification constructs which aren’t limited to the same restrictions. You should be able to create an array of virtual interfaces, assign the array to the physical interfaces, and access the interface handle using an array index.
import uvm_pkg::*;
`include "uvm_macros.svh"
interface ram_if(input bit clk, input bit rst_n);
endinterface
module testbench();
bit clk;
bit rst_n;
virtual ram_if v_intf[3];
v_intf = intf;
for (int i=0; i<3; i++) begin
uvm_config_db#(virtual ram_if)::set(null, "uvm_test_top", $sformatf("vif%0d", i), v_intf[i]);
