Please tell me how to use array return type function in constraint, Below I attached one example.
module array_return_test();
class array_test;
typedef bit [3:0] arr[$];
bit [3:0] g_arr[$];
rand bit [3:0] c_arr[$];
constraint AAA {
c_arr == test(1,2);
function arr test(input bit [3:0] a=1,b=2);
bit [3:0] lcl_arr[$];
for(int i=0;i<5;i++)
lcl_arr.push_back(a+b);
return lcl_arr;
array_test at= new();
initial
at.randomize();
at.g_arr = at.test(i,i+1);
$display($time," C_ARRY = %p; gbl array is %p",at.c_arr,at.g_arr);
In reply to Pawan Kalyan:
class array_test;
bit [3:0] g_arr[$];
constraint AAA {
c_arr == test(1,2);
return lcl_arr;
initial
at.randomize();
You can’t just constraint a queue equal a queue. Several options to fix this:
- Calculate c_arr queue at post_randomize function
- Declare a temporarily to hold test(1,2) and constraint:
constraint AAA {
c_arr.size() == temp_arr.size();
foreach(temp_arr[i]) c_arr[i] = temp_arr[i];
You can only constrain arrays by individual elements. There is no randomization in your example. Please explain why you need this to be part of a constraint. Otherwise, put your function call in pre_ or post_ randomize, or don’t use randomize at all.
I want to assign returned queue(function arr test(input bit [3:0] a=1,b=2);) to another queue in constraint(c_arr == test(1,2);), Then I will pass that queue to another return type function.
PK.
If you just want to make an assignment, just write
c_arr = test(1m2);
Same issue coming.
class array_test;
typedef bit [3:0] arr[];
bit [3:0] g_arr[];
int g =1;
int k =2;
constraint AAA {
c_arr == test(g,k);
//c_arr == test(1,2);
return lcl_arr;
initial
at.randomize();
Results:
Parsing design file ‘fun_return.sv’
Top Level Modules:
array_return_test
No TimeScale specified
Error-[IVCB-INTVAR] Non integral variable
fun_return.sv, 11
array_return_test, “c_arr”
The variable c_arr is not an integral type.
Change the type of the variable or remove it from the constraint expression.
fun_return.sv, 11
array_return_test, “this.test(this.g, this.k)”
The variable this.test(this.g, this.k) is not an integral type.
[b]
2 errors
CPU time: .083 seconds to compile
Same issue coming.
class array_test;
bit [3:0] g_arr[];
rand bit [3:0] c_arr[];
int g =1;
int k =2;
constraint AAA {
c_arr == test(g,k);
bit [3:0] lcl_arr[];
return lcl_arr;
initial
at.randomize();
Results:
Top Level Modules:
array_return_test
fun_return.sv, 11
fun_return.sv, 11
[b]
2 errors
As dave_59 already mentioned “You can only constrain arrays by individual elements” in your code you’re attempting to constrain the entire array, if you need to do so either do a foreach loop or assign it in the post_randomize function.
HTH,
-R
