In reply to Pawan Kalyan:
Hi,
Please tell me how to use array return type function in constraint, Below I attached one example.
module array_return_test();
class array_test;
typedef bit [3:0] arr[$];
bit [3:0] g_arr[$];
rand bit [3:0] c_arr[$];
constraint AAA {
c_arr == test(1,2);
function arr test(input bit [3:0] a=1,b=2);
bit [3:0] lcl_arr[$];
for(int i=0;i<5;i++)
lcl_arr.push_back(a+b);
return lcl_arr;
array_test at= new();
initial
at.randomize();
at.g_arr = at.test(i,i+1);
$display($time," C_ARRY = %p; gbl array is %p",at.c_arr,at.g_arr);
You can’t just constraint a queue equal a queue. Several options to fix this:
- Calculate c_arr queue at post_randomize function
- Declare a temporarily to hold test(1,2) and constraint:
constraint AAA {
c_arr.size() == temp_arr.size();
foreach(temp_arr[i]) c_arr[i] = temp_arr[i];
