How to use a inout port in read and write operation using assign statement
hii…
I am trying to read and write operation in a single port.Using a assign statement and high impedence(z) concept.If i am doing write operation the impedence will be the zero. In read operation the impedence will be high.
How to achive?
Thanks in advancce
In reply to Rajaraman R:
You have two choices. You can use a read/write control signal. In this case, the port is an output when the control is 1, else it can be used as an input when control is 0.
assign myport = control ? data : 'z;
Or you can procedurally assign a register with data when used as an output, and assign it to 'z when used as an input.
logic myport_reg;
assign myport = myport_reg;
// in procedural code
    myport_reg <= data; // myport becomes an output
    myport_reg <= 'z; // myport becomes an input
From a style point of view, I like this approach as it clearly demonstrates a tri-state driver.
logic myport_reg;
assign myport = myport_reg;]
This works, but looks awkward since registers do not load Zs.
