int payload_width = 294;
int test = 0;
bit [320:0]temp_tlp;
int small_code;
temp_tlp = $random;
small_code = temp_tlp[payload_width-26 :0];
$display("small_code=%0d",small_code);
In this example, I want to assign only some bits of temp_tlp to some other variable, but that some bits are not fixed i.e it’s variable. How can I do this?
int test = 0;
int small_code;
var type(temp_tlp) mask; // create a variable mask the same type as temp_tlp
void'(randomize(temp_tlp)); // $random only generates a 32-bit number
mask = (1'b1 << payload_width) -1;
small_code = temp_tlp & mask; // bitwise-and
Note that there is no need to mask a value to fit into a smaller variable. Verilog will silently truncate it.
