How to Restart same thread after disabling it
 repeat(10)begin
   num = $urandom_range(1,100);
   mbx.put(num);
   if(num % 2==!0)begin
    q.push_back(num);
     if(q.size()>5)
      break;
    mbx.get(num);
    q1.push_back(num);
  join_any
  disable fork
In the above code my aim is → a set of 10 numbers generated, if there are more than 5 odd numbers display an error. restart the thread and continue this checking for every groups of 10 numbers.
As per the above code my loop is breaking as soon as mode than 5 odd numbers are generating,however I am confused how to restart the process again and how to check for 10 number groups each time?
Please help me in this.
In reply to rustyguru:
There is only one thread in the code you show, so fork/join_any is meaningless. Fix your example and then maybe we can answer your question.
