How to register associative array of enum with enum key in UVM factory?
Hello,
I have an associative array of enum with another enum as a key to associative array. Currently UVM doesn’t have field macro to register this in the UVM factory.
I am getting below warning if I use “`uvm_field_aa_int_enumkey”
`uvm_field_aa_int_enumkey(e_cmd_type, scen_dist, UVM_ALL_ON)
ncelab: *W,ENUMERR (./testbench.sv,37|69): This assignment is a violation of SystemVerilog strong typing rules for enumeration datatypes.
Is there anyway I can avoid this warning?
Link to edaplayground code. : EDA Playground
Thanks.
In reply to jaykshah_1989:
You can avoid this by not using the UVM field macros. They are extremely inefficient and it is better to code the underlying structures yourself.
In reply to cgales:
Hi Cgales,
Thanks for the response.
Since the macro “`uvm_field_aa_enum_enumkey” is not available in the UVM package we defined it in our local environment and did an explicit cast to the enum type to fix this.
Jay
