How to randomize delay and assign it to clock
I want to randomize delay between (0, 1.28)ns and apply it to clock, any idea how can I do that?
I tried $urandom_range, but it returns only integer value, how can I return values between (0, 1.28)ns?
Thanks!
In reply to rushabhmangukiya27:
$urandom_range(128)/100ns
shortreal rand_val;
  rand_val = $urandom_range(128)/100ns;
  `uvm_info("DELTA", $sformatf("Randomized delta: %f", rand_val), UVM_NONE)
  #rand_val itf.clk_itf[CLK_UNSHAPED].clk =~ itf.clk_itf[CLK_UNSHAPED].clk;
Can I do something like this? if yes then I’m getting following error:
136: token is ā€˜=’
Thanks!
You are not showing enough code. What kind of procedural block is this statement located in?
This works for me
    real rand_val;
and outputs
UVM_INFO testbench.sv(7) @ 0: reporter [DELTA] Randomized delta: 0.380000
Thanks, its working now.
